Code warrior 10.5.1 crashing
885件の閲覧回数
rahul011189
Hi there,
I am using Code warrior 10.5.1 (Windows) for a bare metal project on P4080DS. The issue that I am facing is:
  1. Put project in debug mode
  2. Select any cache from 'Cache' Menu in the debug view
  3. Code warrior crashes (i.e. closes by itself without throwing any error/warning/exception)
Is this a known issue? How can I get around it?
Rahul
695件の閲覧回数
yipingwang
Hello Rahul Garg,
I didn't produce your problem with CodeWarrior 10.5.1, would please capture a screenshot to show your current status?
In addition, would you please also provide the CCS log captured from CodeWarrior IDE?
Please enable CCS log from "Run->Debug Configurations -><project>-core0_RAM_-Connect(Download)->Edit...->Advanced->Advanced CCS setting->Enable logging", and connect to the target from "Run->Debug Configurations-><project>-core0_RAM_-Connect(Download)->Debug”, the CCS log will be displayed in the console panel in CodeWarrior IDE. (If the CCS log in the console is truncated, please enlarge the console buffer from Window->Preferences->Run/Debug->Console->uncheck "Limit console output". Please open the console panel from Window->Show View->Console, and if nothing displayed, please choose the correct session on the right top icon in the panel.)
Yiping
696件の閲覧回数
yipingwang
Hello Rahul Garg,
Yiping
