The installer tells me that I have an unsupported OS, ask do I want to continue, I chose yes, but nothing happens. Can someone direct me to a solution please, no fun working on laptop only..
Tim
Solved! Go to Solution.
Also it a version of Win 7 from an MSDN subcription, so it might not be the version that everyone can buy. The problem is the intaller, not CW. I have other versions installed, so my work around was to copy the entire directory from a vista machine and put it in Win 7.
Tim
Are you using 64-bit Win 7? The tools have only been validated to work on 32-bit Win 7 and Vista.
---Tom
No, it is 32bit OS.
Tim
Tim
