compiling only in arm mode in CW 10.5
729件の閲覧回数
stefanomanca
Hi, where I find the menu to set the compiler only in ARM mode (not thumb)?
Thank you.
Stefano M.
タグ(3)
3 返答(返信)
460件の閲覧回数
Jorge_Gonzalez
Hello Stefano:
That option is in Project -> Properties -> C/C++ Build -> Target Processor.
:smileyalert: BUT if you are using a Kinetis L or Kinetis K device, then you must not uncheck that option, since Cortex M0 and Cortex M4 only support thumb mode, and you will receive errors during compile time.
Hope this helps!
Jorge Gonzalez
460件の閲覧回数
stefanomanca
Hi Jorge, I don't understand. I'm using a kl15, it should have a cortex m0+ core, but I get
"/Sources/ProcessorExpert.c:1:0: error: target CPU does not support ARM mode
mingw32-make: *** [Sources/ProcessorExpert.o] Error 1"
So, what happens?
I'm not so skilled.
Thank you.
460件の閲覧回数
Jorge_Gonzalez
Hello:
That is the error I mentioned. Cortex M0+ in your KL15 cannot support ARM mode instruction set. You need to check that option back, so the compiler uses the thumb instruction set.
To double check this info, take a look at the specifications tab from the next link at ARM web page:
http://www.arm.com/products/processors/cortex-m/cortex-m0plus.php
Regards!
Jorge Gonzalez
