access out of range
access out of range
2,555 次查看
electronicfan
hello,
i have a little problem:
I get an error message: access out of range
my code:
unsigned char my_func(void)
return(array[8]);
This function is outsite of main.c
Hope somebody can help me.
标记 (1)
1,491 次查看
bigmac
Specialist III
Hello electronicfan,
Assuming that you decare an array to contain eight elements,
unsigned char array[8];
The first element of the array will be array[0] and the last element will be array[7].  The element array[8] does not exist.
Mac
1,491 次查看
bigmac
Specialist III
What size have you declared for the global array?  To return the array[8] element, the array size would need to be 9, or more.
Mac
1,491 次查看
electronicfan
hello Mac,
i have a global array of 8 bytes and i will return all 8 bytes to my main function.
Hope you can help me.
electronicfan
1,492 次查看
bigmac
Specialist III
Mac
