Struct define in PE
Struct define in PE
805 次查看
danielchai
Senior Contributor I
I used PEs generate a test project. Then I define a structure in ProcessorExpert.c
typedef struct {
    int a;
    int b;
}Test;
Then in main, I use " Test test_data;" to define it, but when I compile it, it shows:
Test  test_data;
>expression syntax error
Any ideas about this?
Thanks.
-Daniel
710 次查看
TICS_Fiona
According to ANSI rule, the variable defination should be placed at the beginning in the function, and before program code.
710 次查看
danielchai
I found some weird things in ProcesssorExpert.c .
When I put the "Test test_data" before calling the function " PE_low_level_init(); ", it compile the project correctly.
But when I put " Test test-data" after calling the function "PE_low_level_init();", it complains the syntax error.
711 次查看
TICS_Fiona
