Problem with LCF file ROM code relocation
1,326件の閲覧回数
pierreschmidt
I started an MPC5668G project where during startup, I need to copy a portion of code from ROM=>RAM. I want the code to be compiled as beeing part of RAM but located in ROM (so that it can be flashed in non volatile memory).
I say compiled as "part of RAM" because the .elf file should contain RAM located debuging symbols so that when I run the code on a demo board, I can see the high level source at the right place in the RAM.
Here is part of my lcf file content:
MEMORY {
    /*  section allocation */
    applvect_fromCan:    org = 0x10000, len = 0x08
    romfbl:     org = 0x00010008,  len = 0x0001FFF0
    /* ROM 2M*/
    rom2:      org = 0x00012000,   len = 0x001EE000
    /* Code and data to external RAM */
    ram:      org = 0x40004000,   len = 0x32000
    /* Stack at top of external RAM */
    stack:  org = 0x40036000,    len = 0x2000
    /* FLASHDRV */
    flashdrv: org = 0x40000000,   len = 0x1000
    /* Vectors allocated to external RAM */
    vec:    org = 0x40038000,    len = 0x2000
    eth:    org = 0x40001000,   len = 0x3000
SECTIONS {
/* The first group contains code and constant data */
    /* The second group will allocate space for the initialized data
     * (.data/.sdata) and the unititialized data (.bss/.sbss)
    GROUP : {
      EEPDATA  (BSS) : {}
      __DATA_RAM = .;
      .data  (DATA) LOAD(__DATA_ROM) : { *(.data) }
      .sdata (DATA) LOAD(ADDR(.sdata) - ADDR(.data) + __DATA_ROM) : { *(.sdata) }
      .sbss  (BSS) : {}
      .bss   (BSS) : {}
      .osdata (DATA): {}
      .ossdata (DATA): {}
      __DATA_RAM_START   = .;
      RAMCODE    (VLECODE)  LOAD(__TEXT_ROM) :
          *(.text)
      .sdata2    (TEXT)  LOAD(ADDR(.sdata2) - ADDR(RAMCODE) + __TEXT_ROM) :
          *(.sdata2)
      __DATA_RAM_END = .;
    } >ram
    GROUP : {
        APPLVECT_FROMCAN   (DATA) : {}
    } > applvect_fromCan
    GROUP : {
        .text1(VLECODE) : {*(.text_vle)}
        FBLHEADER   (DATA) : {}
        /* This is a dummy section to satisfy the linker for vle!*/
        /* This section should not contain any code.             */
        .text_e (TEXT) : {
            *(.text)
            . = (.+15) & ~15;
        .ctors : {}
        .dtors : {}
        .oscode (TEXT) : {}
        .osconst (CONST) : {}
        .ossconst (CONST) : {}
        .osstring (CONST) : {}
        APPLVECT   (DATA) : {}
        FLASHROM   (DATA) : {}
        __TEXT_ROM = .;
    } > romfbl
The problem is that when I open the generated .hex file, the code corresponding to the .text sections is in the RAM (adresses from 0x40004000) and not in ROM. I expected the code beeing located at __TEXT_ROM address and a free space in RAM from address 0x40004000.
What is wrong with the lcf file?
Thanks a lot.
P.SCHMIDT
タグ(2)
821件の閲覧回数
pierreschmidt
Hello Stanish,
It's OK now, the reason was I had the "Generate ROM image" option unchecked in the control panel. Now everything's fine
2 返答(返信)
821件の閲覧回数
stanish
Hello Pierre,
perhaps the link below answers your question:
How to Copy Function from Flash to RAM & execute it
Stanish
822件の閲覧回数
pierreschmidt
Hello Stanish,
