Optimize compiler for code size
957件の閲覧回数
juliancox
Contributor V
I amusing CW 10.7 with a S08SH4 processor. Is there an option to configure the compiler to minimise code size? Also, what is the approximate difference in code size between the Debug and Release configurations?
タグ(1)
791件の閲覧回数
Hello Julian Cox ,
- Yes, you can reduce code size through Properties-> C/C++ Build ->Setting -> .... as below:
You can find the detail description in "MCU_HCS08_compiler"-> 7.2.3.1.58 -O(-Os, -Ot): Main Optimization Target .
- What about the debug and release of your project ? they can configure by ourself , you can also check the defferent setting in Properties, or you can send your project to me .
Hope it helps,
TIC
792件の閲覧回数
Hello Julian Cox ,
Hope it helps,
TIC
