How can I temporarily switch output from UART to debugger console?
853 次查看
theodortempelme
I am using CW10.6 for Coldfire. Project is ok, output is to UART.
I just want to switch temporarily during development (when serial output happens to be not available).
I would like to switch back and forth with little change to my project. Is that possible?
Thanks for your answer.
664 次查看
ZhangJennie
Hi.
What's your chip part number?
Jennie Zhang
664 次查看
theodortempelme
It is a Coldfire 52259. I had hoped that I could independantly of the used device switch to console output (and back to UART output - and input of course, by the way, but I don't need that at the moment). So I thought it was a CodeWarrior thing, not a Coldfire thing.
664 次查看
Carlos_Mendoza
Hi Theodor,
When a new project is created in CodeWarrior with full board support it will have the option to enable the console I/O or UART functionality, the console support can be enabled by changing the CONSOLE_IO_SUPPORT macro to 1 in the exceptions.c file:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
