Help for using MC9s08gt60
hyty
Hello
I have to use a MC9s08gt60 .
I would like to communicate with a computer with a zigbee connection.
I use a XBEE pro module.
For the moment I would like to send information to the computer by zigbee and I have some difficulties
Can you help me
#include <hidef.h> /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
Function:smileyfrustrated:CI1INT
Input parameters: void
Output Parameters: Void
Description:This has the SCI 1  initializations
 void SCI1INT (void) {
  SCI1BDL=0x0D;
  SCI1C2=0x0C;
  SCI1C1=0x00;
  SCI1BDH=0x00;
Function:smileysurprised:UT_ZIGBEE
Input parameters: char *a
Description:This functions sends data to Zigbee transciever through SCI1.
void OUT_ZIGBEE (char *a)
  while (*a != '\0')
    while (!(SCI1S1 & 0x80));
    SCI1D = *a++;
void main(void) {
char tab[1];
int i=0;
  for(;:smileywink: {
  tab[0]=i;
  OUT_ZIGBEE(tab);
  i++;
  if(i>9)
  i=0;
  } /* loop forever */
  /* please make sure that you never leave main */
peg
Senior Contributor IV
Hello and welcome to the forums hyty,
After a quick look:
Your "array" that you send is only of size 1, where does the null go?
You also never attempt to terminate the string anywhere.
Also you are sending from 0 to 9 binary, did you want this or ASCII 0 to 9.
The first time through, the 0 you load looks like the terminator!
peg
After a quick look:
