CW10.7 Some update sites could not be found - DSC 56F8037
686 次查看
j___
Using CW 10.7 for a DSC project. I found a pretty annoying compiler issue (bug). So, I wanted to see if there is an updated compiler for the 56F8037. Using Help-Check for Updates, I got the following messages:
Some sites could not be found.  See the error log for more detail.
No repository found at http://www.pemicro.com.
No repository found at jar:file:C:%5CUsers%5CLAB%5CDownloads%5CFreescale%5CCW10.7%5CCW%20for%20MCU%2010.7%5Ccom.freescale.mcu10_7.hcs08_rs08.updatesite.zip!/.
No repository found at jar:file:C:%5CUsers%5CLAB%5CDownloads%5CFreescale%5CCW10.7%5CCW%20for%20MCU%2010.7%5Ccom.freescale.mcu10_7.s12z.updatesite.zip!/.
Unable to read repository at http://nxp.com/lgfiles/updates/Eclipse/MCU10_7/updatesite/content.xml.
sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
No repository found at jar:file:C:%5CUsers%5CLAB%5CDownloads%5CFreescale%5CCW10.7%5CCW%20for%20MCU%2010.7%5Ccom.freescale.mcu10_7.kinetis.updatesite.zip!/.
No repository found at jar:file:C:%5CUsers%5CLAB%5CDownloads%5CFreescale%5CCW10.7%5CCW%20for%20MCU%2010.7%5Ccom.freescale.mcu10_7.e200.updatesite.zip!/.
No repository found at jar:file:C:%5CUsers%5CLAB%5CDownloads%5CFreescale%5CCW10.7%5CCW%20for%20MCU%2010.7%5Ccom.freescale.mcu10_7.dsc.updatesite.zip!/.
No repository found at jar:file:C:%5CUsers%5CLAB%5CDownloads%5CFreescale%5CCW10.7%5CCW%20for%20MCU%2010.7%5Ccom.freescale.mcu10_7.coldfire.updatesite.zip!/.
When will these repositories be back up and working?
How can I manually check what the revision history of all DSC compilers that are compatible with CW10.7?
Once I (manually via webpage?) know the compiler history and changes log, how can I manually download the updated compiler that I want?
500 次查看
ZhangJennie
Please try offline updates. You can download them with following attached video.
Jennie Zhang
