I can not build c "Bareboard" project when using sprintf with additional parameters in code. For example:
sprintf(RadioTransmitBuff, "%d\n\r", temperature);
This line causes following error during build:
ARM_GCC_Support/ewl/EWL_C/src/stdio/vsnprintf.c:58: undefined reference to `__pformatter'
mingw32-make: *** [Testing_Sprintf.elf] Error 1
Project builds fine if there is no additional parameters:
sprintf(RadioTransmitBuff, "Hallo\n\r");
I used sprintf with Kinetis Design Studio without any problems therefore it must be something to do with CodeWarrior IDE.
Im using CodeWarrior for MCU Version: 10.6
I hope someone can advice?
Many thanks
Lukasz
解決済! 解決策の投稿を見る。
Thank you Alice for interest.
I have been using KL25Z128 with PE.
Experimentally I figured out the cause of the problem:
It was to do with "I/O support" option during new project setup.
For full support of stdio.h library a "I/O support: UART" option need to be selected.
I found more information on the various options during project setup here:
Tutorial: Printf() with (and without) Processor Expert | MCU on Eclipse
It fix when change Settings/Librarian back to "ewl" from ewl-noio. I thelps with any printf type as sprintf.
Hello Lukasz,
Please tell me which chip , and about your project information , for example , with PE or bare board project ?
And do you sprinft show the result to UART or console window ? Thank ! I will test it on my side .
Alice
