Hi All I have custom board with LS1020A . I am trying to bring it up for the first time . I am using code warrier tap (USB) . I got following error (logged in code warrier server )
check_min_version(serverh=0,*version)
api version: 00000004 00000006
get_connection_count(serverh=0,cc_index=0,*count)
count:1
available_connections(serverh=0,*count,*cc)
connections: {0,73,0xa9fe0d39}
cc_version(serverh=0,cc_index=0,index=0,*version)
get_config_chain(serverh=0,cc=0)
config_server(config_reg=0,config_data=0x00002710)
config_chain(serverh=0,cc=0,count=3,*devlist,*generic)
devlist: ls1020a,dap,sap2
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=0,size=4,*reg)
reg: 0000009E
config_template(coreh.{serverh=0,cc_index=0,chain_pos=0},config_reg=4096,config_data=0x00000001)
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4102,size=4,*reg)
reg: 40025A00
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4103,size=4,*reg)
reg: 21046000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4104,size=4,*reg)
reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4105,size=4,*reg)
reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4106,size=4,*reg)
reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4107,size=4,*reg)
reg: 00038000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4108,size=4,*reg)
reg: 20024800
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4109,size=4,*reg)
reg: 24049340
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4110,size=4,*reg)
reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4111,size=4,*reg)
reg: 00000000
reset_to_debug(serverh=0,cc=0)
ERROR(39): Subcore error encountered during multicore operation
parse_error_ext(coreh.{serverh=0,cc_index=0,chain_pos=0}, 39)
error: LS1020A: Core not responding
Dose any one have any idea about it. I tried to use hard coded RCW option . Am I missing any jtag chain config ??
I am having this same problem on a T2080 custom board, was there ever a fix found for this?
Hello Dhruvalkumar Patel,
Please check whether there is hardware problem on your custom target board.
Please download "AN4878, QorIQ LS1021A Design Checklist - Application Note" from QorIQ LS1021A Dual-Core Communications Processor wi|NXP , and refer to "Figure 31. JTAG interface connection" to check your JTAG interface design, especially nRESET pin.
Yiping
Please take a look on chapter Hard-coded RCW options from LS1021 RM, and choose the value for rcw_src according with your board configuration. One of hard-coded option should work for your board and "Core not responding" error in ccs should gone.
Adrian
It seem the SYSCLK default source IFC_WE0_B is 1 means its not selecting DIFF_SYSCLK which is the default clock source in our case.
Please try using in ccs console, followings commands and provide the output.
config cc cwtap
ccs::config_chain { ls1020a dap sap2 }
ccs::config_template 0 0x1000 1
ccs::write_reg 0 rcw_src 0x9A
ccs::reset_to_debug
Adrian
Thanks for suggestion .
I tried this before and now and I received following messages
(bin) 1 % config cc cwtap
(bin) 2 % ccs::config_chain { ls1020a dap sap2 }
(bin) 3 % ccs::config_template 0 0x1000 1
(bin) 4 % ccs::write_reg 0 rcw_src 0x9A
(bin) 5 % ccs::reset_to_debug
(bin) 6 %
Source is 100 MHz
CPU clock = 800 Mhz
DDR clock = 600 Mhz
I tried to scan the jtag chain and I get following result.
bin) 19 % source IDcode.tcl
Scanning for available TAPs connected via USB.....
+ Available Remote Connections
+ 1 - CodeWarriorTAP - 00:04:9f:03:b1:4c
+ 2 - CodeWarriorTAP - <Specify IP Address>
+ 3 - GigabitTAP - <Specify IP Address>
+ x - Exit Script without Changes
Specify connection:
1
Configuring TAP Interface....
Configured Connection: cwtap : 00:04:9f:03:b1:4c
TDO -----
* Device 0 IDCODE: 5BA00477 Device: Unknown Device
* Device 1 IDCODE: 16B0001D Device: FSL LS1 Device rev 2.x
TDI -----
# configTAP - Redefine TAP interface
# scanboard - Scans the target system
# and returns the JTAG IDCode
# ir - Loopback test
But error still persist
