adv7482 driver:Failed to get default crop rectangle with VIDIOC_G_SELECTION: Invalid argument
706件の閲覧回数
Ohm86
I am using adv7482 driver on iMx8mPlus board.
Please anyone can help me to solve below  issue :
Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument
I have attached the logs file please look into this and help me to get rid of this issues.
Thanks in advance.
3 返答(返信)
658件の閲覧回数
AldoG
Could you share the BSP version that you are using for your test?
Also, are you testing on the EVK?
Best regards/Saludos,
Aldo.
637件の閲覧回数
Ohm86
Hello AldoG,
Thanks for replying.
I am using below bsp version
mickledore imx-6.1.55
and also i have imx8Mplus development board.
gstreamer version is 1.22
530件の閲覧回数
Ohm86
Hello AldoG,
Any Update?? Because  I am still not able to resolve the issue.
I have same issue as mentioned below link:
https://community.nxp.com/t5/i-MX-Processors/custom-image-sensor-driver/m-p/1860270
