CodeWarrior crashing when opening debug configuration
408件の閲覧回数
GustavoTsea
I'm trying to configure to debug a project, but when i click in edit on the debug configuration, the CodeWarrior 10.7 just crash.
I attached a video showing the problem, do you know what is causing this?
356件の閲覧回数
GustavoTsea
I solved the problem by installing the latest multilink driver direct from the PEmicro website. The CodeWarrior has stopped crashing, probably the old driver that was causing codeWarrior to crash.
2 返答(返信)
402件の閲覧回数
ZhangJennie
Hi GustavoTsea
0 The problem may be related with a specific project, test the same with another project.
1 The problem may be related with the workspace. Create a new workspace to test if the problem still exists.
2 The problem may be related with CodeWarrior install. remove the CodeWarrior and reinstall it. test this feature with step 1 then.
3. If the problem still persists after above tests, please use the latest CodeWarrior 11.1.
https://www.nxp.com/design/design-center/software/development-software/codewarrior-development-tools...
Hope this helps
Jun Zhang
357件の閲覧回数
GustavoTsea
