CodeWarrior crashing when opening debug configuration
435 次查看
GustavoTsea
I'm trying to configure to debug a project, but when i click in edit on the debug configuration, the CodeWarrior 10.7 just crash.
I attached a video showing the problem, do you know what is causing this?
383 次查看
GustavoTsea
I solved the problem by installing the latest multilink driver direct from the PEmicro website. The CodeWarrior has stopped crashing, probably the old driver that was causing codeWarrior to crash.
429 次查看
ZhangJennie
Hi GustavoTsea
0 The problem may be related with a specific project, test the same with another project.
1 The problem may be related with the workspace. Create a new workspace to test if the problem still exists.
2 The problem may be related with CodeWarrior install. remove the CodeWarrior and reinstall it. test this feature with step 1 then.
3. If the problem still persists after above tests, please use the latest CodeWarrior 11.1.
https://www.nxp.com/design/design-center/software/development-software/codewarrior-development-tools...
Hope this helps
Jun Zhang
384 次查看
GustavoTsea
