Greetings everyone,
I have a LS1021ATWR board which I want to flash using the CodeWarrior TAP probe.
I've installed Code Warrior Development Studio for Armv7 on Win7 x64
I have a problem when I'm trying to start the debugger on CodeWarrior:
The problem is, when i'm trying to launch ccs.exe manually, it can detect the probe:
I've looked into this: Can't connect CCS
and specifically:
I've tried writing these commands, and I don't have the same output, so I must think there might be some target connection error.
Here is my output:
Here is what happens when I launch the debugger from CodeWarrior:
With log v :
It seems like a connection has been established and then immediatly closed.
I've conncted the probe on my host pc with the USB cable and on my target jtag pins.
I have to mention that my SWITCHES are on default configuration as on Getting Started Guide for LS 1021ATWR here: http://www.farnell.com/datasheets/2000257.pdf
When I power on the board, the LED D5 should turn off according to documentation, but it never does and it keeps lighting. The TX/RX of the probe is linking in a green color, but the RUN/PAUSE led is still in an orange color.
Any help would be apreciated.
Thank you,
Filip
Was this ever resolved? I'm seeing the same things on our custom LS1021A board...
(bin) 315 % delete all
(bin) 316 % config cc cwtap
(bin) 317 % ccs::config_server 0 10000
(bin) 318 %
(bin) 318 % ccs::config_chain {ls1020a dap sap2}
(bin) 319 % display ccs::get_config_chain
Chain Position 0: LS1020A
Chain Position 1: DAP
Chain Position 2: SAP2
(bin) 320 % source lsbp.tcl
(bin) 321 % lsbp::lsbp
reset_to_debug
LS1020A: Core not responding
(bin) 322 % source IDcode.tcl
Scanning for available TAPs connected via USB.....
+ Available Remote Connections
+ 1 - CodeWarriorTAP - 00:04:9f:05:38:1f
+ 2 - CodeWarriorTAP - <Specify IP Address>
+ 3 - GigabitTAP - <Specify IP Address>
+ x - Exit Script without Changes
Specify connection:
1
Configuring TAP Interface....
Configured Connection: cwtap : 00:04:9f:05:38:1f
TDO -----
* Device 0 IDCODE: 5BA00477 Device: ARM DAP rev 5.x
* Device 1 IDCODE: 16B0001D Device: NXP LS1021A rev 2.x
TDI -----
And here is the same without using the lsbp.tcl script:
(bin) 323 % delete all
(bin) 324 % config cc cwtap
(bin) 325 % ccs::config_chain {ls1020a dap sap2}
(bin) 326 % display ccs::get_config_chain
(bin) 327 % ccs::config_template 0 4096 1
(bin) 328 % ccs::write_reg 0 rcw_src 0x9A
(bin) 329 % ccs::reset_to_debug
Hi @addiyi ,
We are facing similar issue. Please find the log when we run above command sequence.
loading history file ... 48 events added
CodeWarrior Connection Server console display active (Tcl8.4.6 / Tk8.4.6)
Loading CCSAPI Tcl interface (/home/firstview/Freescale/CW_ARMv7_v2019.10/CW_ARMv7/ARMv7/CodeWarrior/CodeWarrior_Plugins/Debugger/Protocols/../../../../../../Common/CCS/bin/ccstcl.so)...
Loading Svfburner (/home/firstview/Freescale/CW_ARMv7_v2019.10/CW_ARMv7/ARMv7/CodeWarrior/CodeWarrior_Plugins/Debugger/Protocols/../../../../../../Common/CCS/bin/svfburner.so)...
Server listening on port: 41475
Clients allowed from all hosts
No clients denied
CCSAPI connection #1 accepted from localhost at Wed Dec 23 16:54:19 2020
(bin) 49 % log v
CCS Linux Release Build 490.0.0.190923-p0
verbose logging
(bin) 50 % config cc cwtap
Maximum number of Command Converters reached
config fail
(bin) 51 % ccs::config_chain {{8 1} ls1020a dap sap2}
(bin) 52 % display ccs::get_config_chain
Chain Position 0: Generic Device
Chain Position 1: LS1020A
Chain Position 2: DAP
Chain Position 3: SAP2
(bin) 53 % ccs::reset_to_debug
(bin) 54 %
(bin) 54 % delete all
(bin) 55 % config cc cwtap
(bin) 56 % ccs::config_chain {ls1020a dap sap2}
(bin) 57 % display ccs::get_config_chain
(bin) 58 % ccs::reset_to_debug
(bin) 59 %
Hello Filip,
Please check whether you are using LS1021A 1.0 processor.
In the CCS console, please run "source IDcode.tcl" to get more information.
If you are using reversion 1.0 CPU, please refer to the following procedure.
To debug a target with this processor revision you must use the CFG file "LS102xA_Rev1_ConfigChain.cfg" that can be found at the location
[CW install path]/ARMv7/ARM_Support/Configuration_Files/jtag_chains/. This file will be imported following the next steps:
1. Open "Debug Configurations..." and select your project;
2. Click on the "Edit..." button which can be found next to the drop list called "Connection" from the "Target Settings" view;
3. Click on the "Edit..." button which can be found next to the drop list called "Target";
4. Click on the "Edit..." button which can be found next to the drop list called "Target type";
5. Click "Import..." and then "File System..." and select the file specified above and then click OK until you return
to "Hardware or Simulator Target" window;
6. Select in the "Hardware or Simulator Target" window the initialization and memory files from the project;
7. Click OK until you return to "Debug Configurations..." window and click "Debug".
TIC
It could be because of missing RCW.
Try the followings:
delete all
config cc cwtap
ccs::reset_to_debug
Provide the output.
Adrian
This is my montage:
Note that the D5 led near the boards's jtag pins is always on, as opposed in the Getting Started Documentation I mentioned above.
The RUN/PAUSE Led is always on and orange
and the TX/RX is blinking in a green color (The picture I Took is in between the blinks)
And these are my switches configuration (It's the default configuration as in the Documentation) :
What can I do at this point ? The entire NOR flash of the board has been erased, that's why we've been trying to re-flash it with QorIQ 2.0 SDK included NOR Flash.bin on CodeWarrior.
Can you try the followings commands in ccs:
config cc cwtap
ccs::reset_to_debug
after that:
delete all
config cc cwtap
ccs::reset_to_debug
Provide the output.
Adrian
