need help ?????????
need help ?????????
762件の閲覧回数
davidacosta
//unsigned int   *FLASH_address_pointer;        // after the includes
void READ_Flash(void) {                          // move 128 bytes from FLASH at 0xF800 to FLASH_data[pt]
        byte pt;
        byte tmp;
        FLASH_address_pointer=0xF800+8 ;        // +8 offset for test only
        for(pt=0;pt<128;pt++)
        tmp = (byte)(&FLASH_address_pointer[pt]);   // why does FLASH_address_pointer inc by two ??????
        FLASH_data[pt] = tmp ;                      // you can see it in disassemble
        }                                                          // help  COLDFIRE V1, code warrior V6.3
タグ(1)
3 返答(返信)
612件の閲覧回数
StenS
Since FLASH_address_pointer is a pointer to an integer (16-bits = 2 bytes) it means that FLASH_address_pointer[0] points to F808, FLASH_address_pointer[1] to the next integer = F80A, etc. If FLASH_adress_pointer would point to a char (8 bits = 1 byte), you would get an increment by one.
/Sten
612件の閲覧回数
trytohelp
Hi David,
If you've problem, can you please provide us more details ?
tmp displays a part of address of  the FLASH_address_pointer which is 0xf808.
The FLASH_address_pointer is an unsigned int so coded on 4 bits.
Each time the pointer is incremented, 4 bit is added the memory address and you will have:
     tmp = 8
     tmp = 12
     tmp = 16
According to the \CodeWarrior for Microcontrollers V6.3\Help\PDF\ColdFireV1_Build_Tools_Reference.pdf manual - page 190, we know:
     bool/char is coded on 8 bits
     short is coded on 16 bits
     int if "4-Byte Integers is off" is coed on 16 bits
     int if "4-Byte Integers is on" is coed on 32 bits
     long is coded on 32 bits
     long long is coded on 64 bits
Pascal
Freescale Technical Support
612件の閲覧回数
davidacosta
fixed with "FLASH_data[pt]=((byte*)FLASH_addr)[pt];"
mods please delete this thread
