Help me please i need the dsp56805 flash.cfg for program DSP56F805 with Codewarrior USB TAP.
解決済! 解決策の投稿を見る。
If you have source code and project, you can use CodeWarrior for DSP56800E ver8.3 tools and generate the file and download via usbtap device.
If you just have S-Record file, you have to use FlashOverJtag.exe tools and Wiggler with PC with 25 pin printer port.
Hope it can help you
XiangJun Rong
How can i download CodeWarrior 8.2.3 ?
As you know that the DSP56F805 was launched in Motorola in 2000 year, it uses DSP56800 core instead of DSP56800E core, so the 56800E Flash Programmer does not support DSP56F805.
You have to use flashoverjtag.exe tools to download code via JTAG with Wiggler(parallel command converter) and PC with 25 pin printer port.
If you use USBTAP device, you have to use CodeWarrior for DSP56800E ver8.3 tools, but the CodeWarrior for DSP56800E ver8.3 tools can work on Win XP, it has issue to run on Win 10 OS.
XiangJun Rong
Could you explain how can i flash the .s file into dsp56f805 via usb tap on code warrior 8.3 please.
XiangJun Rong
Thank you.
