I am using Codewarrior development studi for ColdFire V7.1
The test code I have like below:
class testGroupStackTest
{ public:
testGroupStackTest () { dummy =123; }
int getdummy() { return dummy; }
int dummy;
testGroupStackTest testGroupStackInstance;
/* Task IDs */
#define HELLO_TASK 5
extern void hello_task(uint_32);
extern "C" const TASK_TEMPLATE_STRUCT MQX_template_list[] =
/* Task Index, Function, Stack, Priority, Name, Attributes, Param, Time Slice */
{ HELLO_TASK, hello_task, 1500, 5, "hello", MQX_AUTO_START_TASK, 0, 0 },
{ 0 }
void hello_task
uint_32 initial_data
int i;
//testGroupStackTest testGroupStackInstance;
printf("\n Hello World \n");
i=testGroupStackInstance.getdummy();
printf("dummy=%d\n",i);
printf("\n Tests Done \n");
_mqx_exit(0);
if I define testGroupStackInstance as Global instance, the constructor is never got called, the i value I get is Zero. however if I define testGroupStackInstance inside the task, I can get the correct i value dummy =123. What I am missing here?
Your help is great appreciated.
Thanks.
J.
解決済! 解決策の投稿を見る。
MQX overrides C++ initialization code in cw.c, see below:
cw.c
/* Override C++ inititialization so it happens later in _bsp_enable_card */
void __call_static_initializers(void){}
#pragma overload void __call_static_initializers(void);
We need to enable BSPCFG_ENABLE_CPP in the configuration, so later the in _bsp_enable_card(), MQX will do the C++ constructor initialization, see below:
init_bsp.c _bsp_enable_card
#if BSPCFG_ENABLE_CPP
/* initialize C++ constructors */
__cpp_init();
#endif
Happy Thanksgivings
J.
cw.c
__cpp_init();
#endif
Happy Thanksgivings
J.
Hi eGuy
I want to use Cppunit in CodeWarrior too, but I couldn't add it to my project.
In fact I added it to path and CodeWarrior can find header files, but for building the project I am getting so many error messages like:
=#include <string>
>the file 'string' cannot be opened
OR
(C:\cppunit\include\cppunit\TestCase.h|32|20|3|706|3)
= TestCase( const std::string &name );
>declaration syntax error
Can I ask you how did you use CppUnit in your project?
Hello
When you did create your project from a stationery, did you specify you want to use C++?
When you are using global classes, you need a startup code, where the function __call_static_initializers is called. Additionally you need to make sure you link against Cpp run time library (Cpp_4i_CF_Runtime.a for example).
All these settings are set up appropriately if you let the project wizard know you intend to use C++ source file in your application.
CrasyCat
Hi Lundin & CrasyCat,
Thank both of you for your quick response.
I didn't created the project from scatch/stationery. I modified some example code ( in C ) from MQX's example. I added CPP_4i_CF_RegABI_Runtime.a and C++_4i_CF_RegABI_MSL.a manually to the project.
Is there any way that I can specify I want to use C++ in the project setting page? (I tried "Force C++ compilation on C/C++ language page, it doesn't work)
I will try to start project from a stationery later today.
Lundin, I am trying to use CppUnitLite in my project, that CppUnit registration machnism macros require global object instantiation.
Thanks again.
