Read and Write Bytes in a Word
6,384件の閲覧回数
DEMO908AP64
Unsuccessfully, I tried with .l and .h ...
Any idea ?
5 返答(返信)
987件の閲覧回数
eexpress
I thought maybe this way.
#define HB(x) x>>8
#define LB(x) x&0xff
the CodeWarrior' complier can do rest step well.
987件の閲覧回数
bigmac
Specialist III
The original problem was to combine individual bytes into a word, rather than split a word into individual bytes.  However, the macro approach seems a good one.
#define conv2word(hi,lo) (word)hi*256+(word)lo
e.g.
word wordval;
wordval = conv2word(ATD1RH,ATD1RL);
The compiler seems to optimise the code better using multiplication rather than a left-shift process.
Mac
987件の閲覧回数
lupin
Try this:
union {
struct {
byte hi_;
byte lo_;
}part_;
word sum_;
}ful_;
#define hi_byte ful_.part_.hi_
#define lo_byte ful_.part_.lo_
#define full_word ful_.sum_
hi_byte=55;
lo_byte=22;
if(full_word>3200)
Is it OK?
987件の閲覧回数
DEMO908AP64
Thank you Lupin.
I knew that redefining the Word type was a solution.
I would like to avoid to do so and stick to the word type provided in Metrowerks.
I found no trace of the definition of that word type in the Project File.
Anybody, an other idea ?
987件の閲覧回数
alex_spotw
Hi:
If you're using Processor Expert, you can use one of the methods provided by the ATD Bean to read the value as 16 bits.
If you're not using PE, you can use code like:
(From PE)
/* 16-bit register (big endian) */
typedef union {
word w;
struct {
byte high,low;
} b;
} TWREG;
word Read_Sample(void)
TWREG Sample
Sample.b.high = ATD1RH;
Sample.b.low = ATD1RL;
return Sample.w; // Return as word (16 bit)
Alex
