I have fitted an Amfeltec mPCIe to mPCI adapter to my SabreSD board. When I power the system on uBoot runs normally, and Linux starts to boot, then crashes. I have attached the boot log.
I have ensured that the SabreSD and adapter are powered from the same source, I have tried fitting a mPCI card to the adapter and also removing it, and get the same result. I have tried mPCIe cards and Linux boots without any problems, I can then type "lspci" and read information about the card fitted.
It seems that Linux does not like the bridge chip. Can someone please suggest how I can resolve this issue.
I am using kernel 3.0.35, and Ubuntu downloaded from the Freescale website.
Kind regards
Andrew
Original Attachment has been moved to: PCIError-log.txt.zip
Solved! Go to Solution.
After some help from someone at EBV I found the solution here:
https://community.freescale.com/thread/302251
I hope this helps anyone who comes across this post.
Andrew
Andrew
