What is the correct PCB design impedance to use for an LPC4330 GPIO/SGPIO output pin?
Tnx, Tim
Solved! Go to Solution.
Hi Tim,
This question seems the same as your another question post, and I already answer you in you another post:
Please check it.
If you still have question about it, please reply me directly in your another post, thank you!
Kerry
Hi Tim,
Please check it.
Kerry
