Building Qt5 for i.MX6 with YOCTO
For long I looked for a working tutorial to build Qt5 with YOCTO (Yocto Training - HOME) both the libraries for the board image and also a toolchain to build Qt5 applications for the board.
See the full tutorial here:
Building Qt5 using yocto on Wandboard - Wandboard Wiki
The Tutorial is written for the Wandboard that also uses an i.MX6 CPU but you can adapt the tutorial for most of the boards of the i.MX6 family I think - in my case it worked with the i.MX6 SABRE AI without problems.
You only have to adjust the sysroot and maybe also the toolchain-path because the wiki entry is a little bit older :smileyhappy:
Ask your questions for this topic - maybe I can help.
コメント
Thank you Florian for the link.
I followed successfully this tutorial and was able to cross build applications for my wandboard quad from within my Qt Creator on my x64 host. However, when it comes to 'deploy' I receive the following output in Qt Creator:
23:28:42: The remote file system has 46 megabytes of free space, going ahead.
23:28:42: Deploy step finished.
23:28:42: No deployment action necessary. Skipping.
Also, do you know if it is possible to debug the application on the board from within the Qt Creator GUI interface (remotely)?
--Mohamed
Anyone has tried to build Qt5 with webkit? I'm getting this error:
ERROR: Nothing PROVIDES 'ruby-native' (but /home/js/fsl-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtwebkit_5.2.0.bb DEPENDS on or otherwise requires it). Close matches:
  db-native
  bc-native
  byacc-native
NOTE: Runtime target 'qtwebkit-examples' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['qtwebkit-examples', 'qtwebkit', 'ruby-native']
ERROR: Required build target 'core-image-x11' has no buildable providers.
Missing or unbuildable dependency chain was: ['core-image-x11', 'qtwebkit-examples', 'qtwebkit', 'ruby-native']
I get nothing when I do bitbake -s | grep ruby
Hi Mohamed,
you are welcome :smileyhappy:
You should take a look into this Youtube-Video - he explains how to set up everything with qt creator - its for another board, but similiar to a imx6 board: Beaglebone: Qt Creator for C++ ARM Embedded Linux Development - YouTube one of the Videos in the series is explaining every step.
Keep in mind that for the deployment step you also have to select the right qpa in Qt 5 - e.g.: ./myapplication -platform eglfs -plugin tslib (I think in the youtube series he uses the old -qws parameter for deployment to start the Qt Window Server System - in Qt 5 this is obsolete!)
It looks like you want to compile Qt 5.2? I think the layer is not ready yet - make shure that you have the same branch for yocto and the meta-qt5 layer!
Florian
Yes, I'm trying to compile 5.2. Using the branch master for both Yocto and meta-qt5. I'm think that I should wait.
Regards.
Hi Florian
I built an image from the master-next branch and generally everything seems to be working. Except for QT no mediaservices are built. See heremeta-qt5 on master-next does not build video mediaservices
Any idea? I'm still pretty new to yocto and imx6 development...
Hi Florian/Everybody,
florianl
The follow the same exact steps as   mentioned  here, but i keep getting this error in QTCreator Build&Run KIT settings "the compiler cannot produce code for QT version" , has anyone come across this before ? . ! !
Jay
When am trying to cross compile Qt5.3 Beta using toolchain as mentioned, it gives below error..
obj/qguivariantanimation.o: In function `(anonymous namespace)::qUnregisterGuiGetInterpolator_dtor_class_::~qUnregisterGuiGetInterpolator_dtor_class_()':
qguivariantanimation.cpp:(.text+0x10): undefined reference to `QVariantAnimation::registerInterpolator(QVariant (*)(void const*, void const*, float), int)'
qguivariantanimation.cpp:(.text+0x1c): undefined reference to `QVariantAnimation::registerInterpolator(QVariant (*)(void const*, void const*, float), int)'
qguivariantanimation.cpp:(.text+0x28): undefined reference to `QVariantAnimation::registerInterpolator(QVariant (*)(void const*, void const*, float), int)'
qguivariantanimation.cpp:(.text+0x34): undefined reference to `QVariantAnimation::registerInterpolator(QVariant (*)(void const*, void const*, float), int)'
qguivariantanimation.cpp:(.text+0x40): undefined reference to `QVariantAnimation::registerInterpolator(QVariant (*)(void const*, void const*, float), int)'
.obj/qguivariantanimation.o:qguivariantanimation.cpp:(.text.startup+0x18): more undefined references to `QVariantAnimation::registerInterpolator(QVariant (*)(void const*, void const*, float), int)' follow
collect2: error: ld returned 1 exit status
make[3]: *** [../../lib/libQt5Gui.so.5.3.0] Error 1
make[3]: Leaving directory `/home/kishore/Qt5_IMX6/qt-everywhere-opensource-src-5.3.0-beta/qtbase/src/gui'
make[2]: *** [sub-gui-make_first] Error 2
make[2]: Leaving directory `/home/kishore/Qt5_IMX6/qt-everywhere-opensource-src-5.3.0-beta/qtbase/src'
make[1]: *** [sub-src-make_first] Error 2
make[1]: Leaving directory `/home/kishore/Qt5_IMX6/qt-everywhere-opensource-src-5.3.0-beta/qtbase'
make: *** [module-qtbase-make_first] Error 2
Please let me know if anyone has encountered the above error.
Could successfully create the image and run the examples as mentioned in https://community.freescale.com/docs/DOC-99366#comment-11516.
However, when I tried to cross compile Qt5.3 Beta(inorder to run sample app) with the meta toolchain, it is giving errors.
Please let me know if am doing anything wrong in creation of toolchain.
PS: The board is Sabre AI IMX6 with 32 bit ubuntu host system.
I have the same exact problem as above when cross compiling for Qt5.2.1 and 5.3.  Any solutions?
I'm building the Yocto Daisy branch according to the Wandboard requirements.   I'm building with: bitbake core-image-directfb and get the following errors when building Qt:
| arm-poky-linux-gnueabi-g++  -march=armv7-a -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a9 --sysroot=/home/ben/WandBoard/Yocto/daisy/build/tmp/sysroots/wandboard-quad -c -pipe  -O2 -pipe -g -feliminate-unused-debug-types -fvisibility-inlines-hidden -D_REENTRANT -O2 -DLINUX=1 -DEGL_API_FB=1 -DLINUX=1 -DEGL_API_FB=1 -Wall -W -fPIE  -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/qpa/directfb -I../../../../../../../../sysroots/wandboard-quad/usr/include/directfb -I. -o directfb.o ../../../../qtbase-opensource-src-5.2.1/config.tests/qpa/directfb/directfb.cpp
| ../../../../qtbase-opensource-src-5.2.1/config.tests/qpa/directfb/directfb.cpp:45:2: error: #error DirectFB headers are unclean and cannot compile
| make: *** [directfb.o] Error 1
| DirectFB disabled.
|  DirectFB support cannot be enabled due to functionality tests!
|  Turn on verbose messaging (-v) to /home/ben/WandBoard/Yocto/daisy/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtbase/5.2.1-r0/qtbase-opensource-src-5.2.1/configure to see the final report.
|  If you believe this message is in error you may use the continue
|  switch (-continue) to /home/ben/WandBoard/Yocto/daisy/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtbase/5.2.1-r0/qtbase-opensource-src-5.2.1/configure to continue.
| WARNING: /home/ben/WandBoard/Yocto/daisy/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtbase/5.2.1-r0/temp/run.do_configure.31508:1 exit 101 from
|   /home/ben/WandBoard/Yocto/daisy/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtbase/5.2.1-r0/qtbase-opensource-src-5.2.1/configure -v -dont-process -opensource -confirm-license -sysroot /home/ben/WandBoard/Yocto/daisy/build/tmp/sysroots/wandboard-quad -no-gcc-sysroot -prefix /usr -bindir /usr/bin/qt5 -libdir /usr/lib -datadir /usr/share/qt5 -sysconfdir /etc/qt5 -docdir /usr/share/doc/qt5 -headerdir /usr/include/qt5 -archdatadir /usr/lib/qt5 -libexecdir /usr/lib/qt5/libexec -plugindir /usr/lib/qt5/plugins -importdir /usr/lib/qt5/imports -qmldir /usr/lib/qt5/qml -translationdir /usr/share/qt5/translations -testsdir /usr/share/qt5/tests -examplesdir /usr/share/qt5/examples -hostbindir /usr/bin/qt5 -hostdatadir /home/ben/WandBoard/Yocto/daisy/build/tmp/sysroots/wandboard-quad/usr/lib/qt5 -external-hostbindir /home/ben/WandBoard/Yocto/daisy/build/tmp/sysroots/i686-linux/usr/bin/qt5 -platform /home/ben/WandBoard/Yocto/daisy/build/tmp/sysroots/i686-linux/usr/lib/qt5/mkspecs/linux-oe-g++ -xplatform linux-oe-g++ -reduce-relocations -shared -silent -no-pch -no-rpath -pkg-config -no-accessibility -no-alsa -dbus -directfb -evdev -make examples -compile-examples -no-fontconfig -freetype -opengl es2 -eglfs -no-glib -no-gtkstyle -no-iconv -icu -system-libjpeg -no-kms -system-libpng -make libs -no-linuxfb -no-mitshm -no-mtdev -no-nis -openssl-linked -no-openvg -qt-pcre -pulseaudio -release -no-sm -no-sql-db2 -no-sql-ibase -no-sql-mysql -no-sql-oci -no-sql-odbc -no-sql-psql -no-sql-sqlite -no-sql-sqlite2 -no-sql-tds -nomake tests -make tools -tslib -libudev -widgets -no-xcb -no-xcursor -no-xfixes -no-xinerama -no-xinput -no-xinput2 -no-xkb -no-xrandr -no-xrender -no-xshape -no-xsync -no-xvideo -system-zlib -eglfs
| ERROR: Function failed: do_configure (log file is located at /home/ben/WandBoard/Yocto/daisy/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtbase/5.2.1-r0/temp/log.do_configure.31508)
ERROR: Task 739 (/home/ben/WandBoard/Yocto/daisy/sources/meta-qt5/recipes-qt/qt5/qtbase_5.2.1.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1086 tasks of which 1080 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Ben Beckwith
Ok, so the answer was in the error message!  I hacked in a "-continue" to the qtbase.inc in the qt5 recipies and the configure passed.
Cheers,
Ben
Hi sir, I follow the step by step to build the qt for my yocto iMX6 board
It works well when the kit is ubuntu desktop app.
But when I select the yocto kit, it throws following msg:
  1. 09:59:37: Running steps for project 25...
  2. 09:59:37: Starting: "/opt/poky/1.2/sysroots/i686-pokysdk-linux/usr/bin/qmake"/home/davide/qtproject/25/25.pro -r -spec linux-gnueabi-oe-g++CONFIG+=debug
  3. sh: 1: -d: not found
  4. 09:59:37: The process "/opt/poky/1.2/sysroots/i686-pokysdk-linux/usr/bin/qmake" exited normally.
  5. 09:59:37: Starting: "/usr/bin/make"
  6. ../25/mainwindow.ui -o ui_mainwindow.h
  7. make: execvp: ../25/mainwindow.ui: Permission denied
  8. make: *** [ui_mainwindow.h] Error 127
  9. 09:59:37: The process "/usr/bin/make" exited with code 2.
  10. Error while building/deploying project 25 (kit: qt Yocto)
  11. When executing step "Make"
  12. 09:59:37: Elapsed time: 00:00.
I got stuck here for 2 weeks, could you give me some hint to solve this?
I added dbus in build/local.conf in the building of IMX6 with Yocto. However, UDisks command is not found on core image when I build the image with bitbake core-image-minimal.
As a result, it gives below error on IMX6 Sabre AI board when I try to use with Udisks.
response is: QDBusMessage(type=Error, service="", error name="org.freedesktop.DBus.Error.ServiceUnknown", error message="The name org.freedesktop.UDisks was not provided by any .service files", signature="", contents=() )
Please let me know if am missing anything to have UDisks in generated image in this regard.
Thanks and Regards,
Ramakanth
--Mohamed
make sure you have all of the following features included in your build/local.conf file:
EXTRA_IMAGE_FEATURES += "debug-tweaks ssh-server-dropbear ssh-server-openssh tools-debug eclipse-debug"
Hi i work with cross-compile application for freescale imx6, and worked up with his linkYocto Training - HOME, and all right, but in the moment of run the application in QtCreator in the tab Issues show me the next error:
execvp: ../Widget/mainwindow.ui:Permission Denied
You can help me please, thanks.
Regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-1119189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%95%B7%E3%81%84%E9%96%93%E3%80%81%E7%A7%81%E3%81%AFYOCTO(%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20Training%20-%20HOME)%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Qt5%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%AE%9F%E7%94%A8%E7%9A%84%E3%81%AA%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AEQt5%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%E3%81%8B%E3%82%89%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20title%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWandboard%E3%81%A7yocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Qt5%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%20-%20Wandboard%20Wiki%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AF%E3%80%81i.MX6%20CPU%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BWandboard%E7%94%A8%E3%81%AB%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81i.MX6%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%E3%81%AE%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%92%E9%81%A9%E5%BF%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99-%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81i.MX6%20SABRE%20AI%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Esysroot%E3%81%A8%E3%80%81wiki%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%8C%E5%B0%91%E3%81%97%E5%8F%A4%E3%81%84%E3%81%9F%E3%82%81%E3%80%81toolchain-path%E3%82%82%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20-%20%E5%A4%9A%E5%88%86%E7%A7%81%E3%81%AF%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E7%A7%81%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AEimx6%E3%81%AE%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%80%81%E5%BD%BC%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20Training%20-%20HOME%3C%2FA%3E%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A8%A9%E5%88%A9%E3%81%8C%E3%80%81%E3%82%BF%E3%83%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7QtCreator%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E7%9E%AC%E9%96%93%E3%81%AB%E7%A7%81%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EEXECVP%3A..%2Fwidget%2Fmainwindow.ui%3A%E6%A8%A9%E9%99%90%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%81%8F%E3%81%A0%E3%81%95%E3%81%A3%E3%81%9F%E3%83%95%E3%83%AD%E3%83%AA%E3%82%A2%E3%83%B3%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%86%E3%81%BE%E3%81%8F%E5%BE%93%E3%81%84%E3%80%81x64%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AEQt%20Creator%E5%86%85%E3%81%8B%E3%82%89%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%AF%E3%83%AF%E3%83%83%E3%83%89%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%80%8C%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%80%8D%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81Qt%20Creator%E3%81%A7%E6%AC%A1%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AF46%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E7%A9%BA%E3%81%8D%E9%A0%98%E5%9F%9F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%83%BB%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81Qt%20Creator%E3%81%AEGUI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E5%86%85%E3%81%8B%E3%82%89(%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%81%A7)%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E--%E3%83%A2%E3%83%8F%E3%83%A1%E3%83%89%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3Ebuild%2Flocal.conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%2B%3D%20%22debug-tweaks%20ssh-server-dropbear%20ssh-server-openssh%20tools-debug%20eclipse-debug%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6IMX6%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%ABbuild%2Flocal.conf%E3%81%ABdbus%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81bitbake%20core-image-minimal%E3%81%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B3%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%ABUDisks%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81Udisks%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81IMX6%20Sabre%20AI%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BF%9C%E7%AD%94%E3%81%AF%3A%20QDBusMessage(type%3DError%2C%20service%3D%22%22%2C%20error%20name%3D%22org.freedesktop.DBus.Error.ServiceUnknown%22%2C%20error%20message%3D%22The%20name%20org.freedesktop.UDisks%20was%20not%20provided%20by%20any%20.service%22files%22%2C%20signature%3D%22%22%2C%20contents%3D()%20)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E7%82%B9%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%ABUDisks%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%9E%E3%82%AB%E3%83%B3%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%90%E3%82%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81yocto%20iMX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEqt%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%83%E3%83%88%E3%81%8Cubuntu%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81yocto%E3%82%AD%E3%83%83%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E3%82%B9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22margin-top%3A%201em%3B%20margin-bottom%3A%201em%3B%20padding-top%3A%205px%3B%20padding-bottom%3A%205px%3B%20font-family%3A%20'Open%20Sans'%2C%20sans-serif%3B%20list-style-position%3A%20inside%3B%20list-style-image%3A%20initial%3B%20color%3A%20%23afafaf%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22nu19%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E09%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E59%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2037%3A%3C%2FSPAN%3E%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%3CSPAN%20class%3D%22kw1%22%20style%3D%22color%3A%20%23d20020%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E25%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%E3%81%AE%3C%2FSPAN%3E%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97...%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22nu19%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E09%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2059%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E37%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%E9%96%8B%E5%A7%8B%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22st0%22%20style%3D%22color%3A%20blue%3B%22%3E%20%22%2Fopt%2Fpoky%2F1.2%2Fsysroots%2Fi686-pokysdk-linux%2Fusr%2Fbin%2Fqmake%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%2F%3C%2FSPAN%3E%20home%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%2F%3C%2FSPAN%3E%20davide%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%2F%3C%2FSPAN%3E%20qtproject%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2025%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%3C%2FSPAN%3E25.%3CSPAN%20class%3D%22me1%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20pro%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20-%3C%2FSPAN%3E%20r%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20-%3C%2FSPAN%3E%20spec%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%3C%2FSPAN%3Elinux-gnueabi-oe-g%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2B%2B%3C%2FSPAN%3E%20CONFIG%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%2B%3D%3C%2FSPAN%3E%20debug%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3Esh%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E-%3C%2FSPAN%3Ed%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22nu19%22%20style%3D%22color%3A%20%23363534%3B%22%3E09%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E59%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E37%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20%3CSPAN%20class%3D%22st0%22%20style%3D%22color%3A%20blue%3B%22%3E%22%2Fopt%2Fpoky%2F1.2%2Fsysroots%2Fi686-pokysdk-linux%2Fusr%2Fbin%2Fqmake%22%3C%2FSPAN%3E%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de2%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22nu19%22%20style%3D%22color%3A%20%23363534%3B%22%3E09%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E59%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E37%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%E9%96%8B%E5%A7%8B%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22st0%22%20style%3D%22color%3A%20blue%3B%22%3E%22%2Fusr%2Fbin%2Fmake%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E..%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E25%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2F%3C%2FSPAN%3Emainwindow%20%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22me1%22%20style%3D%22color%3A%20%23363534%3B%22%3Eui%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E-%3C%2FSPAN%3Eo%20ui_mainwindow%E3%80%82%3CSPAN%20class%3D%22me1%22%20style%3D%22color%3A%20%23363534%3B%22%3Eh%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3Emake%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20execvp%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20..%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E25%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2F%3C%2FSPAN%3Emainwindow%20%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22me1%22%20style%3D%22color%3A%20%23363534%3B%22%3EUI%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%E3%81%AE%3A%3C%2FSPAN%3E%E6%A8%A9%E9%99%90%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22br0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%5B%3C%2FSPAN%3Eui_mainwindow.%3CSPAN%20class%3D%22me1%22%20style%3D%22color%3A%20%23363534%3B%22%3Eh%3C%2FSPAN%3E%3CSPAN%20class%3D%22br0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%5D%3C%2FSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%20%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E127%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22nu19%22%20style%3D%22color%3A%20%23363534%3B%22%3E09%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E59%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E37%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20%3CSPAN%20class%3D%22st0%22%20style%3D%22color%3A%20blue%3B%22%3E%22%2Fusr%2Fbin%2Fmake%22%3C%2FSPAN%3E%20%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%20%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E2%3C%2FSPAN%3E%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de2%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22me1%22%20style%3D%22color%3A%20%23363534%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%2025%3C%2FSPAN%3E%3CSPAN%20class%3D%22kw1%22%20style%3D%22color%3A%20%23d20020%3B%20font-weight%3A%20bold%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22br0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%E3%81%AE%3C%2FSPAN%3E%20%E3%83%93%E3%83%AB%E3%83%89%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20%2F%3C%2FSPAN%3E%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%20%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%E4%B8%AD%E3%81%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fqt-project.org%2Fdoc%2FQt.html%22%20style%3D%22color%3A%20%2344a51c%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22kw5%22%20style%3D%22font-weight%3A%20bold%3B%22%3E%20(%E3%82%AD%E3%83%83%E3%83%88%3A%20qt%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22br0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%20Yocto)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%3CSPAN%20class%3D%22st0%22%20style%3D%22color%3A%20blue%3B%22%3E%E3%80%8CMake%E3%80%8D%3C%2FSPAN%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22de1%22%20style%3D%22font-family%3A%20'Open%20Sans'%2C%20sans-serif%20!important%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22nu19%22%20style%3D%22color%3A%20%23363534%3B%22%3E09%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E59%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu0%22%20style%3D%22color%3A%20%23363534%3B%22%3E37%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%E7%B5%8C%E9%81%8E%20%3CSPAN%20class%3D%22kw3%22%20style%3D%22color%3A%20%23d20020%3B%20font-weight%3A%20bold%3B%22%3E%E6%99%82%E9%96%93%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22nu8%22%20style%3D%22color%3A%20%23363534%3B%22%3E00%3C%2FSPAN%3E%3CSPAN%20class%3D%22sy0%22%20style%3D%22color%3A%20%23363534%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22nu8%22%20style%3D%22color%3A%20%23363534%3B%22%3E00%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%A72%E9%80%B1%E9%96%93%E7%AB%8B%E3%81%A1%E5%BE%80%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E7%AD%94%E3%81%88%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F!qt5%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AEqtbase.inc%E3%81%AB%E3%80%8C-continue%E3%80%8D%E3%82%92%E3%83%8F%E3%83%83%E3%82%AF%E3%81%97%E3%80%81%E6%A7%8B%E6%88%90%E3%81%8C%E5%90%88%E6%A0%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E6%9D%AF%3CBR%20%2F%3E%E3%83%99%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFWandboard%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6Yocto%20Daisy%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3Abitbake%20core-image-directfb%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6Qt%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7Carm-poky-linux-gnueabi-g%2B%2B%20-march%3Darmv7-a%20-mthumb-interwork%20-mfloat-abi%3Dhard%20-mfpu%3Dneon%20-mtune%3Dcortex-a9%20--sysroot%3D%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fsysroots%2Fwandboard-quad%20-c%20-pipe%20-O2%20-pipe%20-g%20-feliminate-unused-debug-types%20-fvisibility-inlines-hidden%20-D_REENTRANT%20-O2%20-DLINUX%3D1%20-DEGL_API_FB%3D1%20-DLINUX%3D1%20-DEGL_API_FB%3D1%20-Wall%20-W%20-fPIE%20-I..%2F..%2F..%2F..%2Fqtbase-opensource-src-5.2.1%2Fmkspecs%2Flinux-oe-g%2B%2B%20-I..%2F..%2F..%2F..%2Fqtbase-opensource-src-5.2.1%2Fconfig.tests%2Fqpa%2Fdirectfb-%E7%A7%81%E3%80%82%E3%80%82%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2Fsysroots%2Fwandboard-quad%2Fusr%2Finclude%2Fdirectfb%20-I.-o%20directfb.o..%2F..%2F..%2F..%2Fqtbase-opensource-src-5.2.1%2Fconfig.tests%2Fqpa%2Fdirectfb%2Fdirectfb.cpp%3C%2FP%3E%3CP%3E%7C%20..%2F..%2F..%2F..%2Fqtbase-opensource-src-5.2.1%2Fconfig.tests%2Fqpa%2Fdirectfb%2Fdirectfb.cpp%3A45%3A2%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%23error%20DirectFB%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%7C%20%23error%20DirectFB%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%7C%26nbsp%3B%26nbsp%3B%20%5E%3C%2FP%3E%3CP%3E%7C%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3A%20***%20%5Bdirectfb.o%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FP%3E%3CP%3E%7CDirectFB%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7C%20DirectFB%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81%E6%A9%9F%E8%83%BD%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E3%81%9F%E3%82%81%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%7C%20%E6%9C%80%E7%B5%82%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtbase%2F5.2.1-r0%2Fqtbase-opensource-src-5.2.1%2Fconfigure%20%E3%81%B8%E3%81%AE%E5%86%97%E9%95%B7%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%20(-v)%20%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%7C%20%E3%81%93%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E8%AA%A4%E3%82%8A%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%B6%9A%E8%A1%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%7C%20%E7%B6%9A%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtbase%2F5.2.1-r0%2Fqtbase-opensource-src-5.2.1%2Fconfigure%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%7C%E8%AD%A6%E5%91%8A%3A%20%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtbase%2F5.2.1-r0%2Ftemp%2Frun.do_configure.31508%3A1101%E7%95%AA%E5%87%BA%E5%8F%A3%3C%2FP%3E%3CP%3E%7C%26nbsp%3B%20%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtbase%2F5.2.1-r0%2Fqtbase-opensource-src-5.2.1%2Fconfigure%20-v%20-don't-process%20-opensource%20-confirm-license%20-sysroot%20%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fsysroots%2Fwandboard-quad%20-no-gcc-sysroot%20-prefix%20%2Fusr%20-bindir%20%2Fusr%2Fbin%2Fqt5%20-libdir%20%2Fusr%2Flib%20-datadir%20%2Fusr%2Fshare%2Fqt5%20-sysconfdir%20%2Fetc%2Fqt5%20-docdir%20%2Fusr%2Fshare%2Fdoc%2Fqt5%20-headerdir%20%2Fusr%2Finclude%2Fqt5%20-archdatadir%20%2Fusr%2Flib%2Fqt5%20-libexecdir%20%2Fusr%2Flib%2Fqt5%2Flibexec%20-plugindir%20%2Fusr%2Flib%2Fqt5%2Fplugins%20-importdir%20%2Fusr%2Flib%2Fqt5%2Fimports%20-qmldir%20%2Fusr%2Flib%2Fqt5%2Fqml%20-translationdir%20%2Fusr%2Fshare%2Fqt5%2Ftranslations%20-testsdir%20%2Fusr%2Fshare%2Fqt5%2Ftests%20-examplesdir%20%2Fusr%2Fshare%2Fqt5%2Fexamples%20-hostbindir%20%2Fusr%2Fbin%2Fqt5%20-hostdatadir%20%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fsysroots%2Fwandboard-quad%2Fusr%2Flib%2Fqt5%20-external-hostbindir%20%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fsysroots%2Fi686-linux%2Fusr%2Fbin%2Fqt5%20-platform%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fsysroots%2Fi686-linux%2Fusr%2Flib%2Fqt5%2Fmkspecs%2Flinux-oe-g%2B%2B%20-xplatform%20linux-oe-g%2B%2B%20-reduce-relocations%20-shared%20-silent%20-no-pch%20-no-rpath%20-pkg-config%20-no-accessibility%20-no-alsa%20-dbus%20-directfb%20-evdev%20-make%20examples%20-compile-examples%20-no-fontconfig%20-freetype%20-opengl%20es2%20-eglfs%20-no-glib%20-no-gtkstyle%20-no-iconv%20-icu%20-system-libjpeg%20-no-kms%20-system-libpng%20-make%20libs%20-no-linuxfb%20-no-mitshm%20-no-mtdev%20-no-nis%20-openssl-linked%20-no-openvg%20-qt-pcre%20-pulseaudio%20-%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20-no-sm%20-no-sql-db2%20-no-sql-ibase%20-no-sql-mysql%20-no-sql-oci%20-no-sql-odbc%20-no-sql-psql%20-no-sqlite%20-no-sql-sqlite2%20-no-sql-tds%20-nomake%20%E3%83%86%E3%82%B9%E3%83%88%20-make%20%E3%83%84%E3%83%BC%E3%83%AB%20-tslib%20-libudev%20-widgets%20-no-xcb%20-no-xcursor%20-no-xfixes%20-no-xinerama%20-no-xinput%20-no-xinput2%20-no-xkb%20-no-xrandr%20-no-xrender%20-no-xshape%20-no-xsync%20-no-xvideo%20-system-zlib%20-eglfs%3C%2FP%3E%3CP%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Ado_configure(%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtbase%2F5.2.1-r0%2Ftemp%2Flog.do_configure.31508%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF739%EF%BC%88%2Fhome%2Fben%2FWandBoard%2FYocto%2Fdaisy%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase_5.2.1.bb%2Cdo_configure)%20%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%201086%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%201080%20%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E0%E5%80%8B%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%99%E3%83%B3%E3%83%BB%E3%83%99%E3%83%83%E3%82%AF%E3%82%A6%E3%82%A3%E3%82%BA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQt5.2.1%E3%81%A85.3%E3%81%AE%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%99%82%E3%81%AB%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%A8%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-99366%23comment-11516%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-99366%23comment-11516%3C%2FA%3E%20%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Qt5.3%20Beta(%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81)%E3%82%92%E3%83%A1%E3%82%BF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%A8%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%A7%E4%BD%95%E3%81%8B%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPS%3A%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%816%E3%83%93%E3%83%83%E3%83%88ubuntu%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%82%99%E3%81%88%E3%81%9FSabre%20AI%20IMX32%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%89%8D%E8%BF%B0%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Qt5.3%20Beta%E3%82%92%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'Tahoma'%2C'sans-serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%20obj%2Fqguivariantanimation.o%3A%20%E9%96%A2%E6%95%B0%20'(%E5%8C%BF%E5%90%8D%E5%90%8D%E5%89%8D%E7%A9%BA%E9%96%93)%3A%3AqUnregisterGuiGetInterpolator_dtor_class_%3A%3A~qUnregisterGuiGetInterpolator_dtor_class_()'%3A%3CBR%20%2F%3E%20qguivariantanimation.cpp%3A(.text%2B0x10)%3A%E3%80%8CQVariantAnimation%3A%3AregisterInterpolator(QVariant(*)(void%20const*%2C%20void%20const*%2C%20float)%2C%20int)%E3%80%8D%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%20qguivariantanimation.cpp%3A(.text%2B0x1c)%3A%E3%80%8CQVariantAnimation%3A%3AregisterInterpolator(QVariant(*)(void%20const*%2C%20void%20const*%2C%20float)%2C%20int)%E3%80%8D%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%20qguivariantanimation.cpp%3A(.text%2B0x28)%3A%E3%80%8CQVariantAnimation%3A%3AregisterInterpolator(QVariant(*)(void%20const*%2C%20void%20const*%2C%20float)%2C%20int)%E3%80%8D%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%20qguivariantanimation.cpp%3A(.text%2B0x34)%3A%E3%80%8CQVariantAnimation%3A%3AregisterInterpolator(QVariant(*)(void%20const*%2C%20void%20const*%2C%20float)%2C%20int)%E3%80%8D%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%20qguivariantanimation.cpp%3A(.text%2B0x40)%3A%E3%80%8CQVariantAnimation%3A%3AregisterInterpolator(QVariant(*)(void%20const*%2C%20void%20const*%2C%20float)%2C%3CBR%20%2F%3E%20int)%E3%80%8D%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7.obj%2Fqguivariantanimation.o%3Aqguivariantanimation.cpp%3A(.text.startup%2B0x18)%3A%20'QVariantAnimation%3A%3AregisterInterpolator(QVariant%20(*)(void%20const*%2C%20void%20const*%2C%20float)%2C%20int)'%3CBR%20%2F%3E%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%8C%E7%B6%9A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20collect2%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ld%20%E3%81%8C%201%20%E3%81%A4%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20make%5B3%5D%3A%20***%20%5B..%20%2F..%2Flib%2FlibQt5Gui.so.5.3.0%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%201%20make%20%5B3%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fhome%2Fkishore%2FQt5_IMX6%2Fqt-everywhere-opensource-src-5.3.0-beta%2Fqtbase%2Fsrc%2Fgui'%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E%20make%5B2%5D%3A%20***%20%5Bsub-gui-make_first%5D%3CBR%20%2F%3E%20%E3%82%A8%E3%83%A9%E3%83%BC%202%20make%20%5B2%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3CBR%20%2F%3E%20'%2Fhome%2Fkishore%2FQt5_IMX6%2Fqt-everywhere-opensource-src-5.3.0-beta%2Fqtbase%2Fsrc'%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99%20make%5B1%5D%3A%20***%3CBR%20%2F%3E%20%5Bsub-src-make_first%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%20make%3CBR%20%2F%3E%20%5B1%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fhome%2Fkishore%2FQt5_IMX6%2Fqt-everywhere-opensource-src-5.3.0-beta%2Fqtbase'%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99%20make%3A%3CBR%20%2F%3E%20***%20%5Bmodule-qtbase-make_first%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Tahoma'%2C'sans-serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E6%96%B9%E3%81%8C%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E7%A7%81%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100419%3Fet%3Dwatches.email.document_comment%23comment-11312%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-100419%3Fet%3Dwatches.email.document_comment%23comment-11312%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-100419%3Fet%3Dwatches.email.document_comment%23comment-11312%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%95%E3%83%AD%E3%83%AA%E3%82%A2%E3%83%B3%2F%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%20%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fflorianl%22%20target%3D%22_blank%22%3E%E3%83%95%E3%83%AD%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E3%81%AE%E3%81%A8%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81QTCreator%20Build%26amp%3BRun%20KIT%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%80%8C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AFQT%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82!%20!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EJay%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%95%E3%83%AD%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8D%E3%82%AF%E3%82%B9%E3%83%88%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82QT%20%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%E3%80%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AF%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F321596%22%20target%3D%22_blank%22%3Emeta-qt5%20on%20master-next%20%E3%81%AF%E3%83%93%E3%83%87%E3%82%AA%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0yocto%E3%81%A8imx6%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%AB%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E6%96%B0%E3%81%97%E3%81%84%E3%81%A7%E3%81%99...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%815.2%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Yocto%20%E3%81%A8%20meta-qt5%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%20master%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BE%85%E3%81%A3%E3%81%9F%E6%96%B9%E3%81%8C%E3%81%84%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQt%205.2%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%9F%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99-yocto%E3%81%A8meta-qt5%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E5%90%8C%E3%81%98%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92shure%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AD%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%A2%E3%83%8F%E3%83%A1%E3%83%89%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%A6%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%80%81%E3%81%93%E3%81%AEYoutube%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%20-%20%E5%BD%BC%E3%81%AFqt%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%81%9D%E3%82%8C%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81imx6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DkP7uvOu9hoQ%22%20title%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DkP7uvOu9hoQ%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBeaglebone%3AC%20%2B%2B%20ARM%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BFLinux%E9%96%8B%E7%99%BA%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AEQt%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%20-%20YouTube%3C%2FA%3E%20%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81Qt%205%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AAqpa%E3%82%82%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(%E4%BE%8B%3A.%2Fmyapplication)%E3%80%82-platform%20eglfs%20-plugin%20tslib%20(YouTube%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%A7%E3%81%AF%E3%80%81%E5%BD%BC%E3%81%AFQt%20Window%20Server%20System%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%8F%A4%E3%81%84-qws%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Qt%205%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%81%AF%E5%BB%83%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8Cwebkit%E3%81%A7Qt5%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CEM%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E4%BD%95%E3%82%82%20'ruby-native'%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93(%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%20%2Fhome%2Fjs%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtwebkit_5.2.0.bb%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%E6%8E%A5%E6%88%A6%3A%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Edb%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EBC%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Ebyacc-%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E6%B3%A8%3A%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'qtwebkit-examples'%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%E3%80%81%5B'qtwebkit-examples'%E3%80%81'qtwebkit'%E3%80%81'ruby-native'%5D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'core-image-x11'%20%E3%81%AB%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%E3%80%81%5B'core-image-x11'%E3%80%81%20'qtwebkit-examples'%E3%80%81%20'qtwebkit'%E3%80%81%20'ruby-native'%5D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebitbake%20-s%20%7Cgrep%20%E3%83%AB%E3%83%93%E3%83%BC%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IOCTO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX6%E3%81%AEQt5%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%81%8F%E3%81%A0%E3%81%95%E3%81%A3%E3%81%9F%E3%83%95%E3%83%AD%E3%83%AA%E3%82%A2%E3%83%B3%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%86%E3%81%BE%E3%81%8F%E5%BE%93%E3%81%84%E3%80%81x64%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AEQt%20Creator%E5%86%85%E3%81%8B%E3%82%89%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%AF%E3%83%AF%E3%83%83%E3%83%89%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%80%8C%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%80%8D%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81Qt%20Creator%E3%81%A7%E6%AC%A1%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AF46%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E7%A9%BA%E3%81%8D%E9%A0%98%E5%9F%9F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%83%BB%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000aa%3B%22%3E23%3A28%3A42%3A%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81Qt%20Creator%E3%81%AEGUI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E5%86%85%E3%81%8B%E3%82%89(%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%81%A7)%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E--%E3%83%A2%E3%83%8F%E3%83%A1%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-10-2014 09:11 AM
更新者:
