Video Playback Performance Evaluation on i.MX6DQ Board
In this article, some experiments are done to verify the capability of i.MX6DQ on video playback under different VPU clocks.
1. Preparation
Board: i.MX6DQ SD
Bitstream: 1080p sunflower with 40Mbps, it is considered as the toughest H264 clip. The original clip is copied 20 times to generate a new raw video (repeat 20 times of sun-flower clip) and then encapsulate into a mp4 container. This is to remove and minimize the influence of startup workload of gstreamer compared to vpu unit test.
Kernels: Generate different kernel with different VPU clock setting: 270MHz, 298MHz, 329MHz, 352MHz, 382MHz.
test setting: 1080p content decoding and display with 1080p device. (no resize)
2. Test command for VPU unit test and Gstreamer
The tiled format video playback is faster than NV12 format, so in below experiment, we choose tiled format during video playback.
Unit test command: (we set the frame rate -a 70, higher than 1080p 60fps HDMI refresh rate)
    /unit_tests/mxc_vpu_test.out -D "-i /media/65a78bbd-1608-4d49-bca8-4e009cafac5e/sunflower_2B_2ref_WP_40Mbps.264 -f 2 -y 1 -a 70"
Gstreamer command: (free run to get the highest playback speed)
    gst-launch filesrc location=/media/65a78bbd-1608-4d49-bca8-4e009cafac5e/sunflower_2B_2ref_WP_40Mbps.mp4 typefind=true ! aiurdemux ! vpudec framedrop=false ! queue max-size-buffers=3 ! mfw_v4lsink sync=false
3. Video playback framerate measurement
During test, we enter command "echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor" to make sure the CPU always work at highest frequency, so that it can respond to any interrupt quickly.
For each testing point with different VPU clock, we do 5 rounds of tests. The max and min values are removed, and the remaining 3 data are averaged to get the final playback framerate.
#1#2#3#4#5MinMaxAvg
DecPlaybackDecPlaybackDecPlaybackDecPlaybackDecPlaybackPlaybackPlaybackPlayback
270Munit test57.857.357.8157.0457.7857.357.8756.1557.9155.455.457.356.83
GST53.7654.16354.13654.27353.65953.65954.27354.01967
298Munit test60.9758.3760.9858.5560.9757.860.9458.0760.9858.6557.858.6558.33
GST56.75549.14453.27156.15956.66549.14456.75555.365
329Munit test63.859.5263.9252.6363.858.163.8258.2663.7859.3452.6359.5258.56667
GST57.81555.85756.86258.63756.70355.85758.63757.12667
352Munit test65.7959.6365.7859.6865.7859.6566.1649.2165.9357.6749.2159.6858.98333
GST58.66859.10356.41958.0858.31256.41959.10358.35333
382Munit test64.3456.5867.858.7367.7559.6867.8159.3667.7759.7656.5859.7659.25667
GST59.75358.89358.97258.27359.23858.27359.75359.03433
Note: Dec column means the vpu decoding fps, while Playback column means overall playback fps.
Some explanation:
Why does the Gstreamer performance data still improve while unit test is more flat? On Gstreamer, there is a vpu wrapper which is used to make the vpu api more intuitive to be called. So at first, the overall GST playback performance is constrained by vpu (vpu dec 57.8 fps). And finally, as vpu decoding performance goes to higher than 60fps when vpu clock increases, the constraint becomes the display refresh rate 60fps.
The video display overhead of Gstreamer is only about 1 fps, similar to unit test.
Based on the test result, we can see that for 352MHz, the overall 1080p video playback on 1080p display can reach ~60fps.
Or if time sharing by two pipelines with two displays, we can do 2 x 1080p @ 30fps video playback.
However, this experiment is valid for 1080p video playback on 1080p display. If for interlaced clip and display with size not same as 1080p, the overall playback performance is limited by some postprocessing like de-interlacing and resize.
ラベル(4)
コメント
Thanks for presenting this information. It's very beneficial.
I'm debugging a related problem and have few question.
The problem:
I'm playing multiple network streams (4 - 8 - 16) to a 1080p screen using gstreamer. The screen supports DVI only  so I'm using HDMI to DVI cable. Of course I'm scaling down the streams using the mfw_isink element to fit on the screen. All streams starts fine without any noticeable error but after few hours the video freeze's without giving any error messages.
The pipeline I'm using is
                                          vpudec ->
appsr c-> output-selector ->                 input-selector -> mfw_isink
                                          jpegdec->
My questions:
1. The system will be playing video 24/7 and I don't care about power consumption. Is it better to always use the command "echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor" ?
2. Why do you use "queue max-size-buffers=3" between decoder and sink? How do you decide the buffers size=3 ?
3. Do you have any tools for monitoring the VPU and IPU performance?
4. What is more likely to be the bottleneck, the display or the decoder ?
Hi Tarek,
1. freezing issue: can you monitor the RAM memory usage/free (top -b | grep Mem) while your pipelines are running?
2. queue: the 'max-size-buffers' I believe the reason to reduce it is that the vpudec needs some number of buffers running on the pipeline all the time, if the default value is given, the vpudec at some point will run out of buffers.
Hi Leo,
1. I don't see any memory leaks. I've used Top valgrind and mtrace so I have no doubts.
2. I'm not quit sure I understand that! The default value is 20 buffers and we need to reduce this number to 3 buffers so the VPU does not run out of buffers! I would thought that we need to increase the number, right?
jackmao should have a better understanding of why we need to decrease the queue's buffers. AFAIK, the vpudec needs at least 6 buffers running, and we can not change through the vpudec properties, so the only parameter left is the queue's buffers. In fact, I inspected the queue element and seems that the default is 200!!
max-size-buffers    :     Max. number of buffers in the queue (0=disable)
                        flags: readable, writable
                        Unsigned Integer. Range: 0 - 4294967295 Default: 200 Current: 200
BTW,  have you try using the mfw_ipucsc element for down-scaling?
Leo
Hi Leo,
I'm using the mfw_isink which I think is using the same IPU like mfw_ipucsc. Do you think there is additional benefit from using it?
I will try it anyway so my pipeline will be like this:
appsrc -> vpudec -> mfw_ipucsc -> mfw_isink. Is that correct?
Hi Tarek,
the mfw_ipucsc is a color space conversions and resolutiion scaler, so you can remove it from the pipeline if you do not need these features. In the other hand, If you add it and do not add any capsfilter in front, (I believe) it does not do anything.
Leo
Hi Leo,
I do need scaling down  but my question is:
What is the difference between scaling down using mfw_ipucsc and mfw_isink? Is there any performance gain?
Oh I see. I am not sure. jackmao, can you comment on this?
Leo
They should be no big different on scaling down, because they both use IPU
The vpu use 6 buffer for decode, the vl4sink use two of them, the queue use 3 buffer, you can't set too large, otherwise there no enough buffer to run
Hi Junping,
Do I also need to use a queue before mfw_isink?
%3CLINGO-SUB%20id%3D%22lingo-sub-1103986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AAVPU%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E3%81%A7%E3%81%AEi.MX6DQ%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%AE%9F%E9%A8%93%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1416368108%22%20id%3D%22toc-hId--492763754%22%3E1.%20%E4%BA%8B%E5%89%8D%E6%BA%96%E5%82%99%3C%2FH2%3E%3CP%3EBoard%3A%20i.MX6DQ%20SD%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%83%E3%83%88%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%3A1080p%E3%83%92%E3%83%9E%E3%83%AF%E3%83%AA%E3%80%8140Mbps%E3%80%81%E6%9C%80%E3%82%82%E3%82%BF%E3%83%95%E3%81%AAH264%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%A8%E8%A6%8B%E3%81%AA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%85%83%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%2020%20%E5%9B%9E%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%20raw%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%20(%E3%81%B2%E3%81%BE%E3%82%8F%E3%82%8A%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%2020%20%E5%9B%9E%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99)%E3%80%81mp4%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E3%82%AB%E3%83%97%E3%82%BB%E3%83%AB%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81vpu%E5%8D%98%E4%BD%93%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%80%81gstreamer%E3%81%AE%E8%B5%B7%E5%8B%95%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E6%8E%92%E9%99%A4%E3%81%97%E3%80%81%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3A270MHz%E3%80%81298MHz%E3%80%81329MHz%E3%80%81352MHz%E3%80%81382MHz%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8BVPU%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E8%A8%AD%E5%AE%9A%3A1080p%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AE1080p%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%80%82(%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1071144725%22%20id%3D%22toc-hId-1994749079%22%3E2.%20VPU%E5%8D%98%E4%BD%93%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8Gstreamer%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FH2%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E3%81%AFNV12%E5%BD%A2%E5%BC%8F%E3%82%88%E3%82%8A%E3%82%82%E9%AB%98%E9%80%9F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%AE%9F%E9%A8%93%E3%81%A7%E3%81%AF%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E4%B8%AD%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A(%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92-a%2070%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%811080p%2060fps%20HDMI%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%82%88%E3%82%8A%E9%AB%98%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%2Funit_tests%2Fmxc_vpu_test.out%20-D%20%22-i%20%2Fmedia%2F65a78bbd-1608-4d49-bca8-4e009cafac5e%2Fsunflower_2B_2ref_WP_40Mbps.264%20-f%202%20-y%201%20-a%2070%22%3C%2FP%3E%3CP%3EGstreamer%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A(%E6%9C%80%E9%AB%98%E3%81%AE%E5%86%8D%E7%94%9F%E9%80%9F%E5%BA%A6%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A9%E3%83%B3)%3C%2FP%3E%3CP%3Egst-launch%20filesrc%20location%3D%2Fmedia%2F65a78bbd-1608-4d49-bca8-4e009cafac5e%2Fsunflower_2B_2ref_WP_40Mbps.mp4%20typefind%3Dtrue%20!%E3%82%A2%E3%82%A4%E3%82%A6%E3%83%AB%E3%83%87%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9!vpudec%20framedrop%3Dfalse%20!%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3D%203!mfw_v4lsink%20sync%3Dfalse%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--736309738%22%20id%3D%22toc-hId-187294616%22%3E3.%20%E5%8B%95%E7%94%BB%E5%86%8D%E7%94%9F%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%E6%B8%AC%E5%AE%9A%3C%2FH2%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E4%B8%AD%E3%81%AB%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8Cecho%20performance%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2Fscaling_governor%E3%80%8D%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%80%81CPU%E3%81%8C%E5%B8%B8%E3%81%AB%E6%9C%80%E9%AB%98%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AB%E8%BF%85%E9%80%9F%E3%81%AB%E5%BF%9C%E7%AD%94%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%95%B0%E3%81%AA%E3%82%8BVPU%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%8C%81%E3%81%A4%E5%90%84%E3%83%86%E3%82%B9%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%815%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%A8%E6%9C%80%E5%B0%8F%E5%80%A4%E3%81%AF%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%80%81%E6%AE%8B%E3%82%8A%E3%81%AE%203%20%E3%81%A4%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%B9%B3%E5%9D%87%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E5%86%8D%E7%94%9F%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E3%81%8C%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22width%3A%20960px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22xl64%22%20height%3D%2220%22%20width%3D%2264%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%231%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%232%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%233%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%234%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%235%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3EMin%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%E6%9C%80%E5%A4%A7%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-left%3A%20medium%20none%3B%22%20width%3D%2264%22%3E%E5%B9%B3%E5%9D%87%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl64%22%20height%3D%2220%22%20style%3D%22border-top%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E12%E6%9C%88%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E12%E6%9C%88%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E12%E6%9C%88%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E12%E6%9C%88%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E12%E6%9C%88%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E5%86%8D%E7%94%9F%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl65%22%20height%3D%2240%22%20rowspan%3D%222%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-bottom%3A%20black%200.5pt%20solid%3B%22%3E270M%20%E9%96%B2%E8%A6%A7%E6%95%B0%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%83%BB%E3%83%86%E3%82%B9%E3%83%88%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.8%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.3%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.81%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.04%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.78%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.3%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.87%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.15%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.91%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E55.4%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E55.4%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.3%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.83%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl64%22%20height%3D%2220%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3EGST%E3%81%AE%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E53.76%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E54.163%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E54.136%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E54.273%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E53.659%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E53.659%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E54.273%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E54.01967%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl65%22%20height%3D%2240%22%20rowspan%3D%222%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-bottom%3A%20black%200.5pt%20solid%3B%22%3E298M%20%E9%96%B2%E8%A6%A7%E6%95%B0%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%83%BB%E3%83%86%E3%82%B9%E3%83%88%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E60.97%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.37%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E60.98%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.55%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E60.97%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.8%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E60.94%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.07%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E60.98%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.65%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.8%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.65%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.33%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl64%22%20height%3D%2220%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3EGST%E3%81%AE%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.755%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E49.144%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E53.271%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.159%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.665%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E49.144%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.755%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E55.365%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl65%22%20height%3D%2240%22%20rowspan%3D%222%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-bottom%3A%20black%200.5pt%20solid%3B%22%3E329M%20%E9%96%B2%E8%A6%A7%E6%95%B0%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%83%BB%E3%83%86%E3%82%B9%E3%83%88%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E63.8%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.52%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E63.92%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E52.63%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E63.8%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.1%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E63.82%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.26%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E63.78%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.34%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E52.63%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.52%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.56667%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl64%22%20height%3D%2220%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3EGST%E3%81%AE%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.815%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E55.857%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.862%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.637%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.703%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E55.857%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.637%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.12667%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl65%22%20height%3D%2240%22%20rowspan%3D%222%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-bottom%3A%20black%200.5pt%20solid%3B%22%3E352%E3%83%A1%E3%83%BC%E3%83%88%E3%83%AB%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%83%BB%E3%83%86%E3%82%B9%E3%83%88%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E65.79%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.63%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E65.78%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.68%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E65.78%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.65%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E66.16%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E49.21%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E65.93%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E57.67%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E49.21%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.68%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.98333%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl64%22%20height%3D%2220%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3EGST%E3%81%AE%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.668%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.103%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.419%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.08%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.312%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.419%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.103%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.35333%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl65%22%20height%3D%2240%22%20rowspan%3D%222%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-bottom%3A%20black%200.5pt%20solid%3B%22%3E382M%20%E9%96%B2%E8%A6%A7%E6%95%B0%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%83%BB%E3%83%86%E3%82%B9%E3%83%88%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E64.34%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.58%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E67.8%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.73%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E67.75%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.68%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E67.81%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.36%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E67.77%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.76%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E56.58%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.76%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.25667%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl64%22%20height%3D%2220%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3EGST%E3%81%AE%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.753%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.893%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.972%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.273%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.238%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E58.273%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.753%3C%2FTD%3E%3CTD%20align%3D%22right%22%20class%3D%22xl64%22%20style%3D%22border-top%3A%20medium%20none%3B%20border-left%3A%20medium%20none%3B%22%3E59.03433%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E6%B3%A8%3ADec%E5%88%97%E3%81%AFvpu%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89fps%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%80%81Playback%E5%88%97%E3%81%AF%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E5%86%8D%E7%94%9Ffps%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22untitled.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22untitled.JPG%22%20style%3D%22width%3A%20483px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38120i0221159547DFFBCE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22untitled.JPG%22%20alt%3D%22untitled.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Euntitled.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E%E5%8D%98%E4%BD%93%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E3%82%88%E3%82%8A%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E3%81%AA%E3%81%AE%E3%81%AB%E3%80%81Gstreamer%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E3%81%BE%E3%81%A0%E6%94%B9%E5%96%84%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3FGstreamer%E3%81%AB%E3%81%AF%E3%80%81vpu%20api%E3%82%92%E3%82%88%E3%82%8A%E7%9B%B4%E6%84%9F%E7%9A%84%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8Bvpu%E3%83%A9%E3%83%83%E3%83%91%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AF%E3%80%81%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%20GST%20%E5%86%8D%E7%94%9F%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AF%20vpu%20(vpu%20dec%2057.8%20fps)%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%B6%E7%B4%84%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81vpu%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E5%A2%97%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8vpu%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C60fps%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E5%88%B6%E7%B4%84%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%8860fps%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGstreamer%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E8%A1%A8%E7%A4%BA%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%81%AF%E3%80%81%E5%8D%98%E4%BD%93%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E7%B4%841fps%E3%81%AB%E3%81%99%E3%81%8E%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%81%A8%E3%80%81352MHz%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%811080p%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%AE%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%201080p%20%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E3%81%AF%20~60fps%20%E3%81%AB%E9%81%94%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E5%82%99%E3%81%88%E3%81%9F2%E3%81%A4%E3%81%AE%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E6%99%82%E9%96%93%E3%82%92%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%812%20x%201080p%20%40%2030fps%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E5%AE%9F%E9%A8%93%E3%81%AF%201080p%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%AE%201080p%20%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%201080p%20%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E8%A7%A3%E9%99%A4%E3%82%84%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%A9%E3%81%AE%E5%BE%8C%E5%87%A6%E7%90%86%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E5%86%8D%E7%94%9F%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFJunping%E3%80%81%3C%2FP%3E%3CP%3Emfw_isink%E5%89%8D%E3%81%AB%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Evpu%20%E3%81%AF%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%206%20%E3%81%A4%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81vl4sink%20%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%E3%81%AE%202%20%E3%81%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AF%203%20%E3%81%A4%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%A4%A7%E3%81%8D%E3%81%99%E3%81%8E%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%AA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%A6%E3%82%82%E5%A4%A7%E3%81%8D%E3%81%AA%E9%81%95%E3%81%84%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%81%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82IPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%82%E3%80%81%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjackmao%22%20target%3D%22_blank%22%3E%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%83%9E%E3%82%AA%3C%2FA%3E%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emfw_ipucsc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%A8%20mfw_isink%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AE%E5%90%91%E4%B8%8A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tarek%2C%3C%2FP%3E%3CP%3E%3CEM%3Emfw_ipucsc%3C%2FEM%3E%20%E3%81%AF%E8%89%B2%E7%A9%BA%E9%96%93%E5%A4%89%E6%8F%9B%E3%81%8A%E3%82%88%E3%81%B3%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E6%96%B9%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E5%89%8D%E3%81%ABcapsfilter%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81(%E7%A7%81%E3%81%8C%E4%BF%A1%E3%81%98%E3%81%A6%E3%81%84%E3%82%8B)%E4%BD%95%E3%82%82%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFmfw_ipucsc%E3%81%A8%E5%90%8C%E3%81%98IPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%86mfw_isink%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%BF%BD%E5%8A%A0%E3%81%AE%E5%88%A9%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eappsrc%20-%26gt%3B%20vpudec%20-%26gt%3B%20mfw_ipucsc%20-%26gt%3B%20mfw_isink.%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjackmao%22%20target%3D%22_blank%22%3Ejackmao%3C%2FA%3E%20%E3%81%AF%E3%80%81%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E7%90%86%E7%94%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%82%88%E3%82%8A%E3%82%88%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82AFAIK%E3%81%A7%E3%81%AF%E3%80%81vpudec%E3%81%AF%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%826%E3%81%A4%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81vpudec%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%94%AF%E4%B8%80%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A7%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%80%81%E7%A7%81%E3%81%AF%E3%82%AD%E3%83%A5%E3%83%BC%E8%A6%81%E7%B4%A0%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF200%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99!!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Emax-size-buffers%20%3A%20%E6%9C%80%E5%A4%A7%E3%82%AD%E3%83%A5%E3%83%BC%E5%86%85%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E6%95%B0%20(0%3D%E7%84%A1%E5%8A%B9)%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%83%A9%E3%82%B0%3A%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%8F%AF%E8%83%BD%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%8F%AF%E8%83%BD%3C%2FP%3E%0A%3CP%3E%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E6%95%B4%E6%95%B0%E3%80%82%E7%AF%84%E5%9B%B2%3A%200%20-%204294967295%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%20200%20%E7%8F%BE%E5%9C%A8%3A%20200%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81mfw_ipucsc%E8%A6%81%E7%B4%A0%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3E1.%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%AA%E3%83%BC%E3%82%AF%E3%81%AF%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AFTop%20valgrind%E3%81%A8mtrace%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E7%96%91%E3%81%84%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E2.%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E8%AB%A6%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93!%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%80%A4%E3%81%AF%2020%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A7%E3%80%81VPU%3CEM%3E%3CSTRONG%3E%20%E3%81%8C%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E3%81%84%E6%9E%9C%E3%81%9F%20%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%20%E3%80%81%E3%81%93%E3%81%AE%E6%95%B0%E3%82%92%203%3C%2FSTRONG%3E%3C%2FEM%3E%3CSTRONG%3E%3CEM%3E%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%3C%2FEM%3E%3C%2FSTRONG%3E%20%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%95%B0%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%82%88%E3%81%AD%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tarek%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%20RAM%20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%BF%E7%94%A8%E9%87%8F%2F%E7%A9%BA%E3%81%8D%E5%AE%B9%E9%87%8F%20(top%20-b%20%7C%20grep%20Mem)%20%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E2.%E3%82%AD%E3%83%A5%E3%83%BC%3A%E3%80%8Cmax-size-buffers%E3%80%8D%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E7%90%86%E7%94%B1%E3%81%AF%E3%80%81vpudec%E3%81%8C%E5%B8%B8%E3%81%AB%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%80%A4%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81vpudec%E3%81%AF%E3%81%82%E3%82%8B%E6%99%82%E7%82%B9%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E3%81%84%E6%9E%9C%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E6%80%A7%E8%83%BD%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E6%9C%89%E7%9B%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%EF%BC%9A%3C%2FP%3E%3CP%3Egstreamer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0(4-8-16)%E3%82%921080p%E7%94%BB%E9%9D%A2%E3%81%AB%E5%86%8D%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E9%9D%A2%E3%81%AFDVI%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81HDMI-DVI%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AB%E5%8F%8E%E3%81%BE%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%20mfw_isink%20%E8%A6%81%E7%B4%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E7%B8%AE%E5%B0%8F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AF%E7%9B%AE%E7%AB%8B%E3%81%A3%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%95%B0%E6%99%82%E9%96%93%E5%BE%8C%E3%81%AB%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%9B%E3%81%9A%E3%81%AB%E3%83%93%E3%83%87%E3%82%AA%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vpudec%20-%26gt%3B%20%3C%2FP%3E%3CP%3Eappsr%20c-%26gt%3B%20output-selector%20-%26gt%3B%20input-selector%20-%26gt%3B%20mfw_isink%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20jpegdec-%26gt%3B%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%3A%3C%2FP%3E%3CP%3E1.%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF24%E6%99%82%E9%96%93%E5%B9%B4%E4%B8%AD%E7%84%A1%E4%BC%91%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%97%E3%80%81%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%AF%E6%B0%97%E3%81%AB%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E5%B8%B8%E3%81%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%22echo%20performance%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2F%22%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E3%81%8C%E8%89%AF%E3%81%84%E3%81%A7%E3%81%99%E3%81%8Bscaling_governor%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E2.%20%3C%2FSPAN%3E%20%E3%81%AA%E3%81%9C%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%A8%E3%82%B7%E3%83%B3%E3%82%AF%E3%81%AE%E9%96%93%E3%81%A7%20%22%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3Equeue%20max-size-buffers%3D3%22%3C%2FSPAN%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%3D%203%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%B1%BA%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E3.%20VPU%E3%81%A8IPU%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E4.%E3%83%9C%E3%83%88%E3%83%AB%E3%83%8D%E3%83%83%E3%82%AF%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%81%8C%E3%82%88%E3%82%8A%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎10-09-2012 08:13 AM
更新者:
