I am trying to import a CodeWarrior 10.0 (Build: 100611) project but the ProcessorExpert.pe does not show any of the components in the directory structure.
In the project's other workspace, there was the ProcessorExpert.pe file and it had 3 folders below it. Within these folders there were the processor and several components. When I import, it only shows the xml file itself (ProcessorExpert.pe) with an icon with blue "<>" symbols on it.
The components still show up in the original project.
When I import I do "File -> Import -> General -> Existing Projects into Workspace" and I select the directory with the .cproject file.
Am I importing the project correctly or do I need to pass the workspace directory around as well?
Thank you,
Josh
Nevermind.
If you select "Processor Expert -> Bring Processor Expert Views" they will show up.
