Dear all,
I have a doubt related S-Record file generation.
I'm correct if I assume that with v2 colfire having contiguous sectors flash always the output S-record file generated will have adjacent address flash where the data will be loaded.
What I mean that the S-record file generated is linear asigned. The address is not jumping within flash from one to another address.
Thanks in advanced.
Solved! Go to Solution.
Hello
Yes S record file should contain records with adjacent address.
CrasyCat
Hello
CrasyCat
