Is there any way to change the default tab expansion in the Hiwave debugger from the default of four? I would like to set it to eight, which matches the source files I am working with.
I am running the debugger standalone, and not from the IDE.
David
Solved! Go to Solution.
Hello
As far as I know this is not possible with the debugger today.
CrasyCat
Hello
CrasyCat
