iMX8X TEMPMON accuracy
Kazuma_Sasaki
Senior Contributor I
iMX8X contain the temperature monitor/sensor IP module inside. But, I could not find any description about accuracy of these sensors in datasheet and reference manual. How about accuracy these sensors?
Kazuma Sasaki.
Tags (2)
joanxie
yes, my understanding is that the accuracy is about the same as the MX6.
joanxie
you can refer to the application note as below:
https://www.nxp.com/docs/en/application-note/AN4579.pdf
Kazuma_Sasaki
Hi Joan,
Do you have any update? I am sorry for bothering you. but, I still need your help.
Kazuma Sasaki.
joanxie
Kazuma_Sasaki
Dear Joan,
I appreciate your support.
Kazuma Sasaki.
Kazuma_Sasaki
Hi Joan,
Thank you for your support. Did you mean the temperature sensor of iMX8X family is same specification as iMX6 familly?
If yes, iMX8X's temperature sensor accuracy is +/-10deg. Is it right?
Related thread : i.MX6S die temperature sensor accuracy
Kazuma Sasaki.
