iMX8X contain the temperature monitor/sensor IP module inside. But, I could not find any description about accuracy of these sensors in datasheet and reference manual. How about accuracy these sensors?
Kazuma Sasaki.
Solved! Go to Solution.
yes, my understanding is that the accuracy is about the same as the MX6.
you can refer to the application note as below:
Hi Joan,
Do you have any update? I am sorry for bothering you. but, I still need your help.
Kazuma Sasaki.
Dear Joan,
I appreciate your support.
Kazuma Sasaki.
Hi Joan,
Thank you for your support. Did you mean the temperature sensor of iMX8X family is same specification as iMX6 familly?
If yes, iMX8X's temperature sensor accuracy is +/-10deg. Is it right?
Related thread : i.MX6S die temperature sensor accuracy
Kazuma Sasaki.
