Does NXP keep legacy Linux SDK's?
kurt_copley
I need to recreate a U-Boot that was built with the gcc-4.3.74-eglibc-2.8.74/powerpc-linux-gnu/bin/powerpc-linux-gnu-gcc tool chain but have been unable to find it anywhere.
I found major and minor, but not the build version. I suspect it's custom to the NXP tool suite since the install path was /opt/freescale/usr/local/ for the defunct system I'm trying to rebuild.
Thank you.
yipingwang
Hello Kurt Copley,
This version Toolchain is provided in ISO P1020_P2020RDB_20101101_ltib.iso, I have uploaded this ISO in the following link
https://drive.google.com/open?id=1iS3StsubAI-AumRvEHV1FEHcJnU4yvV2
After installing this ISO and run "./ltib", toolchain gcc-4.3.74-eglibc-2.8.74 is installed in /opt/freescale/usr/local/.
Yiping
kurt_copley
Thank you. My employer won't allow me to download it from there. Do you know that version is still available from ltib?
yipingwang
The ltib ISO is not available in www.nxp.com.
