Why I cannot set WD_DIS to logic 1 by SPI?
I set WD_DIS to 1 ,but when I read it,it always 0.
What should I do to disable watchdog in BE13?
Could you please let us know the part number you are working on? This will help us assign the right engineer to help you.
SC900719
Hi the only part that I found is the SC900719AAF but this is obsolete and no longer supported..Sorry
Have a good day
