Xenomai Latency Distribution on LS1043 Result
cheon798
First, in the results in the slide below, the Duration is referred to as 00:10:00, which is supposed to be 10 minutes, right?
Secondly, if you used the default latency tool provided by xenomai, the number of samples per second (default period: 100 [us]) is 600. + 353 + 84 + 7 + 3 + 1 = 600).
Then, is the latency test only performed for 6/100 [sec]? Or am I wondering if I ran 600 latency tests in 10 minutes?
The last one is about latency result.
Is latency.max [us] really 0.68 [us]? No matter how I googled, I couldn't find latency.max below 1 [us].
So is the latency test api provided by xenomai correct? In addition, inquire under which condition the test was performed.
Labels (2)
