I am New in Ethernet protocol implementation or network protocol implementation. I read ENET Module chapter in K60 Manual, but i need more details information on ENET Module. So, please suggest any Application Note on K60 ENET Module.
Nandish Jasani.
Download the open source version of the uTasker project from GITHUB and follow this tutorial:
https://www.utasker.com/docs/KINETIS/uTaskerV1.4_Kinetis.pdf
It runs a simulated Kinetis part with its Ethernet module so you can do both practical tests and step through the code to see how the Ethernet module operates (how it is configured, controlled and how it works internally - address filltering, interrupt generation, buffer copying and so on).
Mark
[uTasker project developer for Kinetis and i.MX RT]
