PN7150 About Tag read error
h-kawada
I am troubled with the following operation of PN7150.
[ Execution environment ]
  BOARDs :
  1). OM5578/PN7150ARD
  2). LPCxpresso824-MAX
  IDE : MCUXpressoIDE 10.3.1
  Project : NXP-NCI_LPC82X_example
  NxpNci.c : '18/12/19 14:11
  nfc_task.c : '18/12/19 14:11
  PN7150 CORE_INIT_RSP :
  NCI << 40 01 19 00 03 1e 03 00 08 00 01 02 03 80 81 82 83 02 d0 02 ff 02 00 04 88 10 01 a0
  VICCs : ISO15693 NXP ICODE SLIX
  1) UID = e0 04 01 50 65 6d 40 b5
  2) UID = e0 04 01 50 65 6c 74 0f
  3) UID = e0 04 01 50 65 6c e9 df
[ Operation verification ]
  [1] 1 VICC : No.1
      NCI << 61 05 15 01 01 06 06 ff 01 0a 00 00 b5 40 6d 65 50 01 04 e0 06 80 80 00
       | RF_INTF_ACTIVATED_NTF <-- OK
  [2] 1 VICC : No.2
      NCI << 61 05 15 01 01 06 06 ff 01 0a 00 00 0f 74 6c 65 50 01 04 e0 06 80 80 00
  [3] 1 VICC : No.3
      NCI << 61 05 15 01 01 06 06 ff 01 0a 00 00 df e9 6c 65 50 01 04 e0 06 80 80 00
  [4] 2 VICCs : No.1 & 2
      NCI << 61 03 0f 01 06 06 0a 00 00 b5 40 6d 65 50 01 04 e0 02
      NCI << 61 03 0f 02 06 06 0a 00 00 0f 74 6c 65 50 01 04 e0 01
       | RF_DISCOVER_NTF <-- OK
  [5] 2 VICCs : No.1 & 3
      NCI << 61 03 0f 02 06 06 0a 00 00 df e9 6c 65 50 01 04 e0 01
  [6] 2 VICCs : No.2 & 3
      NCI << 60 07 01 a1
      NCI << 60 07 01 a1
      NCI << 60 07 01 a1
      NCI << 60 07 01 a1
       | CORE_GENERIC_ERROR_NTF <-- NG
       | A1 : DISCOVERY_TARGET_ACTIVATION_FAILED
[1] - [5] Normal operation.
[6] Why can't the PN7150 identify tags?
h-kawada
PN7150B0HN/C11006 is installed
OM5578/PN7150ARD is
How can I get it?
The board I have now
I wish I could upgrade
h-kawada
Data Sheet
Modified Date : 25 Jun 2020
User Guide
Modified Date : 26 Jun 2020
Adder definition of PN7150B0HN/C11006
h-kawada
Hello
Thank you for your response
> We are planning to release a new version fixing
Waiting for good news
h-kawada
h-kawada
Discontinuation Notification 202001024DN
Why was PN7150B0HN / C11004E discontinued?
IvanRuiz
Yes, I just received internal feedback about this. They let me know that we had to discontinue this version because of a major regression lately found.
We are planning to release a new version fixing this but are still waiting for R&D planning for which we will appreciate your comprehension on this.
Thank you very much.
BR,
Ivan.
h-kawada
Should have seen the latest datasheet sooner.
[ PN7150 Version ]
  NCI >> 20 01 00
  answer[8] : 0x08
  answer[17+answer[8]] : 0x10
  answer[18+answer[8]] : 0x01
  answer[19+answer[8]] : 0xA0
  Version C11002
[ PN7150 Product data sheet ]
  Rev. 3.9__28 August 2019
  317439
6 Versions
   6.1 Version C11004
      A fix has been added that addresses a collision
      resolution problem for ISO 15693 tags in case
      there are multiple tags in the field.
   6.2 Version C11002
      initial released version.
Equipped with PN7150B0HN / C11004
Does OM5578 / PN7150ARD exist?
h-kawada
Performed additional testing
  1) UID = e0 04 01 50 d6 bb 63 76
  2) UID = e0 04 01 50 d6 bb 63 09
  [1] 1 VICC : No.1
      NCI << 61 05 15 01 01 06 06 ff 01 0a 00 00 76 63 bb d6 50 01 04 e0 06 80 80 00
  [2] 1 VICC : No.2
      NCI << 61 05 15 01 01 06 06 ff 01 0a 00 00 09 63 bb d6 50 01 04 e0 06 80 80 00
  [3] 2 VICCs : No.1 & 2
      NCI << 61 03 0f 01 06 06 0a 00 00 76 63 bb d6 50 01 04 e0 02
      NCI << 61 03 0f 02 06 06 0a 00 00 09 63 bb d6 50 01 04 e0 01
IvanRuiz
Please let me know if I understood your requirement.
When you try to read ICODE SLIX 1 & 2 specifically it is not possible to activate them? If so, have you modified something in the SW to detect multiple devices?
Thank you for clarifying.
BR,
Ivan.
h-kawada
Hello
Thank you for your reply
Yet I have not changed the settings
The same execution environment
[Anti-collision failure]
[Anti-collision success]
After this, I want to change the PF_BIT_RATE setting.
Are there any other measures?
h-kawada
Changing PF_BIT_RATE did not change the result
  Tried value :
    0x00 : 106k
    0x01 : 212k
    0x02 : 424k
    0x03 : 848k
    0x80 : 26k
    0x81 : 212k & 424k
