i have signed the NDA,it have the mfp components of the nxp,i have enter the SL1,but i don't know how to enter SL3,how can i do it,
below is my code
1.
/* SL0*/
memset(TemBuf,0x00,16);//key
uiRet = phalMfp_WritePerso(palMfp,1,0x9000,TemBuf);
uiRet = phalMfp_WritePerso(palMfp,1,0x9001,TemBuf);
uiRet = phalMfp_WritePerso(palMfp,1,0x9002,TemBuf);
uiRet = phalMfp_WritePerso(palMfp,1,0x9003,TemBuf);
uiRet = phalMfp_CommitPerso(palMfp, 1);//personal
SL0:above code id ok,it can enter SL1.
2.
/*SL2/3*/
how can i enter SL2 or SL3 ?
should i select phalMfp_AuthenticateSL1? or select phalMfp_AuthenticateSL2? or select phalMfp_AuthenticateSL3?
how can i set the argument?thank you very much.
(1)phalMfp_AuthenticateSL1(palMfp, 1,1,0x9003, 0, 0,16, TemBuf, 0,PcdCap2In,PdCap1,PdCap2);
(2)phalMfp_AuthenticateSL2(palMfp, 1,0,0x9002, 0, 0,16, TemBuf, 0,PcdCap2In,PdCap1,PdCap2,pKmf);
(3)phalMfp_AuthenticateSL3(palMfp,0,0x9003, 0, 0,16, TemBuf, 0,PcdCap2In,PdCap1,PdCap2);
if i set those argument,it will be error,how can i do it?thank you very much.
Hello huliping@kingberry.com.cn,
On this community we handle question regarding MATLAB/Simulink or our toolboxes. Unfortunately I can't help you on this topic, but I can suggest that you open a ticket for technical support here (go to 'Go to Ticket').
Hope this helps,
Razvan.
ok,thank you for your help,thank you very much.
