I am working on SJA1105S ethernet switch.
I want know which port scheduler algorithm this switch supports.
ramesh
Thanks for the reply.
I would like to know, whether SJA1105S chip has register bit supports for this. Because in configuration I have parameter for Scheduler Algorithms Types as -1) Deficit Round Robin 2) Strict Priority 3) Weighted Round Robin.
So how do i configure switch to work according to selected scheduler algorithm types.
Ramesh
The only scheduling algorithms supported by the SJA1105 are Strict Priority and Credit Based Shaping with a total of 16 AVB queues which can be assigned to the 4 ports. There is no round-robin scheduling algorithm between the priority queues, but some fairness and bandwidth reservation can be attained by using CBS.
Thank you for your kind information
Ramesh
