kI2C_SlaveTransmitAckEvent
jun1
Contributor V
Always I am indebted.
Master-slave communication is being confirmed using “SDK_2.6.0_MKE04Z128xxx4 \ boards \ frdmke06z \ driver_examples \ i2c \ interrupt_b2b_transfer \ slave".
Added kI2C_SlaveTransmitAckEvent to i2c_slave_callback () routine, but does not break there.
When does this event occur?
Is there an API to set ACK / NAK to output manually?
Thank you.
jun.
Sabina_Bruce
Hello Jun,
Are you using another board to work as master? If so, could you please specify what kind of data you are sending using this peripheral. So that I can try to reproduce this from my end.
Sabina
Sabina_Bruce
Hello Jun,
Sabina
jun1
Contributor V
Thank you very much.
I'll try.
jun
