Enet_rmii_udp Transmit Problem
876152220
I am using MPC5748G enet_rmii_udp example code on s32 design studio IDE.
When I send data less than 12 bytes, it can work and PC can receive. But if it more than 12 bytes, the PC can not receive.
I check the code many times, and I can not find why it does so. Is there anyone can help me to solve the problem.Thanks.
PetrS
I think the frame lengths are not properly defined in the example. Try the modification as per the ethernet example enet_rmii_upd
BR, Petr
