Erreur Debug kit de dev OM27462CDK :
louis_eeckeloot
quand j'essaye de lancer le debug d'un programme sur MCUXpresso via le kit de développement NXP OM27462CDK, j'obtiens l'erreur suivante (photo jointe)
je n'arrive pas à trouver une solution
nxf54945
Hello Louis Eeckeloot,
I hope you are doing well.
Before programming and debugging your board, it is necessary to configure the device interaction with your computer. Could you please confirm you are updating the user EEPROM? Here you will find a post on how to do so.
I hope this information helps. Please let us know if you have any doubts or concerns and we will be glad to assist you.
Javier
