S32K144EVB: Unable to receive the data by UART serial communication
shriyawangikar1
1. I am using Hterm software to send and receive the data using seial communication.
2. I can able to transfer the data using OpenSDA UART pins from S32 design studio to Hterm.
3. However I am unable to receive the data send by the Hterm on S32DS.
Kindly give me suggestions.
Tags (3)
jiri_kral
are you using example like lpuart_echo or it is your own program?
Jiri
shriyawangikar1
Yes sir..I used example program....I tried with below commands individually but did not work
1. LPUART1_receive_and_echo_char();
2. LPUART1_receive_char();
jiri_kral
here is thread related to your question - https://community.nxp.com/message/1182697?commentID=1182697#comment-1182697
Your terminal is probably not sending correct end character.
Jiri
