hai
In our sdk example file there is some difference having to declare the pin plz let me know which one need to assign
SYSCON->SYSAHBCLKCTRL |= GPIO;
LPC_SYSCON->SYSAHBCLKCTRL |= GPIO;
Hi, Aravind,
Regarding your question, it is dependent on which structure instance pointer in *.h is defined, if the SYSCON structure instance pointer is defined, you use the one:SYSCON->SYSAHBCLKCTRL |= GPIO;, if the LPC_SYSCON structure instance pointer is defined, you use the one:LPC_SYSCON->SYSAHBCLKCTRL |= GPIO;,
If you still have question about the topic, pls tell us the part number and the SDK package version.
XiangJun Rong
thank you
