This is Alex from Leaptronix.
We are the third party of programmer.
Could we apply QN9080DHN programming spec?
My email is: overseas@leap.com.tw
Thank you and have a good day.
Solved! Go to Solution.
Hi Ryan,
There's this document: QN908x Production Flash Programming but this use the J-Link programmer as a base. Also you could look in the user guide, in the chapter 28. Flash memory controller, explains the process and commands to write in the memory flash.
I hope this can help you.
Alexis Andalon
Dear Alex,
The QN9080 use the SWD interface to program it but I'm not sure if this is what you mean.
Could you explain more about it?
Alexis Andalon
Dear Alexis:
We need the document to know how to program the IC.
This document will have program detail.
Hi Ryan,
Alexis Andalon
