SWO Trace Debuggiing examples
a_bet
Hi to you all,
I'm trying to use LPCLink2 to debug my application, which is based on a LPC4370. I need to profile a function I wrote, in particular I need to know, the execution time.
I know it can be done using ITM (instrumentation Trace Macrocell), but the user guide from NXP does not provide info on how to do use it to profile a function.
Can someone pointing me to examples/material to learn how to use these advanced debugging tools?
Andrea
BlackNight
Hi Andrea,
maybe this?
ARM SWO Performance Counters | MCU on Eclipse
I hope this helps,
Erich
a_bet
Hi ErichS‌ , thanks a lot for the reply and for the beautiful blog (one of the best LPC resources... which I knew already!).
I will dig out the profiling as soon as I'm done with functional evaluation.
Unfortunately I'm in deep troubles using LPCOpen vcom example to stream data over USB between Matlab and my LPC4370.
Hello Andrea Bettati,
About the vcom example, you can create a new case in this thread:  https://community.nxp.com/community/lpc?tid=community
Alice
