What is the difference between A0 & B0 Silicon Revisions of IMX8QX Processor ?
rvalvekar
Hello Everyone,
I have been trying to search extensively for the difference between the Silicon Version of IMX8 Processors. I am unable to find a concrete information about this revision change.
Where would be a good place to get this information ?
Also does the Revision Change affect the bootloader, the scu-firmware and the arm trusted firmware ? Since then the revisions will also affect the flash.bin container.
Thank You for the support and information.
Hi Rohan
B0 fixed some errata and implemented various performance and design changes.
Hi Rohan
dhty2015
Hello Igor,
Now the provided image can no longer be used directly in A0 version. What configuration should I modify if I compile it myself?
rvalvekar
Hello Igor,
Thank you for Your assistance and support.
