I was wondering if there was any tutorials on this site showing how to create a new project with a MCUXpresso SDK using IAR embedded workbench?
Thanks for any help!
Hi Joseph:
There is new project wizard in MCUXpresso IDE, it provides a number of ways of quickly selecting the target for the project that you want to create. Unfortunately there is not a similar wizard for IAR.
For IAR users, I would suggest you start with a existing IAR demo. If you want to start from scratch, you need to add source code manually. add board files, clock_config files, and pin_mux files, and some drivers and start up code...
