USB HOST_CDC problem with FRDMK64
ktmirshad767
I am working on FRDMK64 board.
I make a new project selecting USB host CDC type and run it, then I get "unknown devide attach" when I connect FTDI usb to serial converter. (but it is working with MK22FN512 USB_DEVICE_CDC). any configuration is required to make it work?
jingpan
Hi Muhammad,
I haven't FTDI, but I have CH340 and CP2102. They are USB to serial converter too. I think they have same characteristic. I found their interface descriptor are vendor specific. Their bInterfaceClass is 0xff. They need driver suport. I guess FTDI is same with them. You can set a breakpoint in USB_HostCdcEvent() in host_cdc.c, observe hostInterface->interfaceDesc->bInterfaceClass value. If it is 0xff, then the interface descriptor is also vendor specific. You have to modify the demo code to fit for the chip.
Jing
ktmirshad767
Hi Jing Pan,
If you have modified demo code for CH340 or CP2102, please share. Then I can Refer that and modify the demo code fit for FTDI.
Muhammad
ktmirshad767
Hi Jing Pan,
I am Using KSDK_1.3.0  USB Host cdc_serial example. In that where I make this Change?
Muhammad
jingpan
Hi Muhammad,
KSDK1.3.0 is a very old version. Now the most update KSDK is 2.4. I strongly suggest you to use new KSDK to start your project.
Jing
