PCF2129T
PCF2129T
niyathihere4u
I am using RTC PCF2129T for my application.
I was succesfully able to set time and get time with this RTC. However, when i try to set a minute alarm,the minute alarm interrupt doesn't get generated.  So, i read all the 3 control registers. When i read them without any write i dont get the reset values for these registers. Also, even if i make a write to these registers, nothing gets changed.
TomasVaverka
Hi Niyathi,
Is is hard to say where the problem might be without seeing your code or scope shots illustrating write/read transactions on the bus.
You may find useful my example code where I also use a minute interrupt.
Tomas
niyathishenoyk
Hi Tomas,
Thank you for the sample code.Set time and get time is already working for me. I need a functionality where an alarm function is generated based on a particular time set. Also, is there some power on sequence that needs to be followed? Because after power on when i try to read the register values its supposed to give reset values,however it is giving me garbage values.I am also not able to write anything into the rtc registers.
