What onboard USB controller is implemented into i.MX 8m?
contact3
What implementation you are using internally as the USB host controller on the i.MX 8M series? EX, Intel/ASmedia... version number, etc. This is not mentioned on your data sheets. Thank you very much!
Hi Ty
seems this is designware cores, as one can find its
references in sect.11.1.3.23.2 Diagram  - "DWC_*"    i.MX8MDQ Reference Manual
https://www.nxp.com/webapp/Download?colCode=IMX8MDQLQRM&Parent_nodeId=1480454149826718646460&Parent_...
contact3
Thank you muchly igor, though the link currently does not work.
