Is the Modular Iot Gateway running Atmosphere specific software?
mrharmonsr
Is the Modular Iot Gateway using 6lowpan to transfer data or is it more specific to Atmosphere?
Can I use other gateways?
Can I run gateway software on other embedded linux boxes?  oDroid?  Raspberry Pi?
estephania_mart
Are you referring to this Modular IoT Gateway Reference Design|NXP  ?  If that it's the case, could you please submit your question in this community? NXP Modular IoT Framework  , you will need to join the group to submit your question
Estephania
