I understand the POR and SW bits of the RCM-SRS0 register.
I see the POR (and LVD) bits on a power on of my K22F eval board.
I see SW bit set when using a JTAG re(start). See https://community.nxp.com/message/1056898?q=Detecting%20Different
I also see an SW bit set when calling the core_cm4.h function __NVIC_SystemReset()
What I would like to have is one or more additional bits to distinguish additional reasons for calling __NVIC_SystemReset().
What are recommended procedures to have data persist across a restart session?
Hi Keith
See the first few paragraphs of Appendix B of http://www.utasker.com/docs/uTasker/uTaskerSerialLoader.pdf
for a simple method of leaving a reason for a commanded software reset.
Mark
For less questions and restrictions, and faster, cheaper developments: try uTasker for Kinetis
